My xbox 360 wont read any games and it now wont eject
SOURCE: my xbox 360 wont read halo 3 but reads my other
Your disk may be damaged. If it has scratches on it that can cause major problems. But the worst problems are caused by fingerprints. Fingerprints prevent the laser from reading the data on the disk. If your disk has fingerprints, run it under the water faucett and, using a soft cloth (the kind you would clean eyeglasses with), wipe from the center to the outside of the disk, not in a circle. If the problem persists, the Halo 3 data on your hard drive may be corrupted. Delete the data and try starting the game then.
SOURCE: xbox 360 wont read any disc
Here's a link to a site that gives a lot of details about how to repair the DVD drive on your xbox. http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm Sometimes all it takes is to clean the dust off the lens and mirror. This site offers a tutorial on how to do that. However, before you take your xbox apart and void any warranty I recommend you go to http://support.xbox.com/support/en/us/nxe/default.aspx. This is the Microsoft support web site. You can determine if your xbox is still under warranty. If it is I recommend having Microsoft do the repair.
SOURCE: it wont read 360 games but it reads original Xbox games
cd drive error, if its an older xbox thats what it would be, either that or disk read error thing, i would suggest taking it in somewhere and have people look at it. or check the xox 360 games to see if there are any big scratches. that would be a big problem if there r scratches.
SOURCE: wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
mine does the same thing it sucks the day i got it 2 i say we sue that s.o.b bill gates for making such ****!!!!!!!!!!!!!!!
