Question about Samsung Office Equipment & Supplies
Photo copying not funtioning in Samsung SCX 3201 G Printer Showing red Indicator
Iam getting printouts from system, able to scan files to system. While trying to photo copy the red indicator glows & Not getting any outputs
SOURCE: can't scan and copy from computer
Why can't you use a regular USB printer cable instead? Those conversion cables are not the most reliable or compatible solutions.
Posted on Mar 08, 2008
taki99
  • 112 Answers
SOURCE: Wrong colors when printing on photo paper
yha way not
if you worry about wrong colors
it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
Posted on Dec 16, 2008
SOURCE: Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position.
Posted on Jan 06, 2009
pineworks
  • 4041 Answers
SOURCE: When i attempt to copy or scan a black and white
Hi there my name is Clive too,
Ok you can only try Clive to gave it a good clean out It worth a try.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
  • 11800 Answers
SOURCE: Samsung SCX-4 x 24 laser
It doesn't do it because the printer processor doesn't get any signal from the scanner sensor. First make sure that the light for the scanner works - if it doesn't then dismantle the scanner to access the carriage - check the CCFL tube and then the inverter that is powering it and fix what is broken.
 If the light works then it's in the sensor - either the data cable is loose (reseat it) or the sensor itself has died. In that case you must send the unit to an authorised repair shop, they are the only ones with access to replacement parts.
Posted on Sep 11, 2010
Samsung SCX-3201G printer driver free download
Samsung SCX-3201G printer driver no download plzzzzz help me
Jun 21, 2012 | Office Equipment & Supplies
Driver Samsung SCX - 3201G Printer
I have Samsung SCX-3201 G printer. Printing & Xerox working is OK, but scan facility is not working because the original software is not working or it is hanging. please give me a solution for get the original software or scan drivers.
With Regards
Vijay
Feb 13, 2012 | Samsung Office Equipment & Supplies
I want to chip reset samsung scx 3201 model printer
i want to chip reset samsung scx 3201 model printer
Apr 11, 2011 | Samsung Office Equipment & Supplies
Just brought my SCX 4100 into use in my office, worked perfectly at home on a Windows XP system but in the office on a vista system the printer works fine, the copy function within smart thru 4 functions...
Did you install the correct driver including the scan driver? The drivers are available at the Samsung Site: http://www.samsung.com/us/support/downloads/SCX-4100 . Click on the Driver tab for most or the Software Tab for the SmarThru4 program. Make sure to get the correct version for the OS on the office computer. Generic OS drivers often only run the printe, not the scanner. Uninstall the generic driver before attempting to nstall the Samsung driver.
Next check the data cable. Scanners require bi-directional communication with the computer and can fail when the printer works.
I hope this helps.
Jan 24, 2011 | Samsung SCX-4100 All-In-One Laser Printer
Printout is black
please change your copier toner unite it demage
Aug 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Simply don't know how to begin using the scan function on the SCX Samsung multi-functioned printer.
First of all, you have to install the drivers, that can be done by installing the applications that came with the CD that came with the printer
Then when you have installed these drivers, restart your computer.
Simply now, put the paper you want to scan in the scanner, and press the scan button.
Jun 01, 2009 | Samsung SCX 4200 All-In-One Laser Printer
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position. Once you unlock that blue button by pulling towards you, switch off the printer and again switch on the printer.
Jan 06, 2009 | Samsung SCX-4720FN All-In-One Laser...
Copy size
Please let me know If you make a scan. The Output its same as in the hard copy or Shrinked. If its shrink then its problem from scanner. Needs a setup. Else Refer back to me.
Mar 13, 2008 | Samsung SCX 4521F All-In-One Laser Printer
How do I scan with the samsung scx-4200?
The solution has been posted!
Never mind not being able to scan, try sorting out your reading issues first.
Mar 04, 2008 | Samsung SCX 4200 All-In-One Laser Printer
100 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
