Question about Panasonic Viera TH-42PX80U Plasma TV
Panasonic viera TV compatibility problem
I attached my panasonic Tv to a sony receiver good quality picture but no sound. Things that I did: 1. checked and replaced all the hdmi wires. 2. tried my sony receiver on to a samsung tv, good picture and sound. 3. turned off the "viera link" on the panasonic tv, receiver radio finally works but still no sound on tv and receiver. tried putting 'home theater' as default on the TV but unable to because vera link is off, when vera link is on then muting on the receiver comes up. 4. checked many times that I am on the right input on the receiver, because I have a good picture on the tv. Needs Help!
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
  • 8909 Answers
SOURCE: 1998 32" PANASONIC TV. When
You have dry joints!
Look for poor soldering on any heavy object including heat sinks/transformers etc.
Posted on Dec 31, 2010
SOURCE: Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Posted on Jan 25, 2011
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
Why panasonic viera picture quality all blurred
If you are driving it from a laptop, and both the laptop screen and TV are on at the same time then the laptop will be sending a blurred picture to the TV.
Toggle the laptop's picture output so that only the TV is displaying an image.
Sep 05, 2014 | Panasonic Viera TX-L39E6B 39" LED TV...
DOES PANASONIC 42" VIERA TH-L42U5S" BROADCAST VIDEO FILES FROM FLASH DRIVE? WHEN I CONNECT MY USB DRIVE TO THE TV, THE VIDEO FILES COULD NOT BE RECOGNIZED BY TV, JUST MUSIC AND PICTURES CAN BE VIEWED....
No this TV does not process video files from USB. To improve sound quality reset the sound settings to midrange on all settings. Too much bass causes the sound to be muddy, especially on vocals
Feb 01, 2018 | Panasonic 42" Viera U5 Series LCD HDTV -...
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TC P50S2 tv loses sound fairly often. use at&t uverse hd receiver and after rebooting the dvr/receiver, the muting problem is gone for between 1 day and and 2weeks. at&t says the tv...
Use the component connection not the HDMI. Some of the ATT boxes have issues with the HDMI ports. Uverse is only broadcast in 1080i not p so you will not lose any video quality.
Apr 27, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Our Panasonic Viera 46
Seems like a hardware problem. Something is probably overheating or something like that.
I would suggest either returning/exchanging the TV (2 wks is usually in most return policies) or if you can't do that, register your TV with panasonic. After registering, call them up for service covered by your 1 yr warranty.
Aug 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-42PX80U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
