Question about Relic Degrade Pocket Watch
Relic Pocket watch model ZR85062 does not move
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
SOURCE: Need a new back for my Relic (Susan G. Koman) watch
The only way I can see is to try to contact FOSSIL (Relic are made by Fossil).
You will find Customer Support as well as How to contact etc.
The link is here:
www.fossil.com
If you can't find what you want, send an email to them explaining what exactly you are looking for.
Do not forget to rate, please.
Posted on Jan 04, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Posted on Mar 13, 2009
disap1
  • 98 Answers
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Posted on Jan 09, 2010
Need battery number for relic women's watch model zr33940 battery was lost
take it to a store that sells watches they might be able tomatch a watch to it .
Apr 08, 2015 | Relic Watches
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
Dec 24, 2013 | Relic Degrade Pocket Watch
How do you set the time on a Relic ZR85049 pocket watch?
the crown in the top of 12 o'clock must be pulled. and turn it to adjust the time.
Jul 23, 2011 | Relic ZR85049 Pocket Watch for Men
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Some of the numbers on my relic pocket watch fell off.
Unfortunately you will not be able to get the watch glass off without braking it. Watch glasses usually are friction set or glued into the watch bezel using special press or special glue. Both are of such a good quality, that it is allmost impossible to remove the glass without special equipment.
You can try, of course, but it will be on your own risk.
The best way is to find your nearest watch repair shop and ask for help.
Feb 10, 2009 | Relic Degrade Pocket Watch
How to set the time on relic watches
Dec 27, 2008 | Relic Degrade Pocket Watch
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic Degrade Pocket Watch Logo
23 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
