Question about Epson L800 - printer - color - ink-jet
PRINT LINES ON PICTURES BUT NOZZLE CHECK I S OKEY?
kaienana
  • 10 Answers
SOURCE: printing blue picture with yellow lines
I had this problem too.
There was no low ink warning but one colour was missing, as seems to be your case.
Either the jet is still blocked or the colour is dry.
I had to change the cartridge and all worked fine.
Posted on Jul 07, 2008
websnail
  • 419 Answers
SOURCE: nozzle check
Running cleaning cycles will only clear out some clogging but not really solid clogs which it sounds like you have with this printer.
I'd recommend finding a suitable cleaning solution (you'll have to google that I'm afraid) and then soak a pad of kitchen roll or similar in it... Place this pad on the printheads resting pad area (you may need to manually move the printhead to one side to do this.
... the push the printhead into the resting/parked position and leave overnight. This allows the cleaning solution to wick into the printhead nozzles and break down any clogged ink.
Run a single cleaning routine the next day (don't try to rush things!) and a single nozzle check. Leave for an hour and repeat a nozzle check.
You may need to repeat the cleaning pad routine but even a solidly clogged printer can be brought back to life so long as you are patient and you have the right solution (obviously).
Hope that helps.
Posted on Jan 23, 2009
aicaxz
  • 511 Answers
SOURCE: Horizontal lines in photos
Do head cleaning. Print at best photo quality.
Posted on May 05, 2010
  • 241 Answers
SOURCE: Printer is blurry and does not print lines properly.
The cause of your problems is you may need to replace your printheads or clean them. By doing a search on the internet you may find a solvent or information on how to clean the printheads.
Posted on Jun 04, 2010
Tirzo
  • 94 Answers
SOURCE: blue doesn't print. I've cleaned the
It appears that the printer is malfunctioning and will require service. I suggest contact its manufacturer to verify the warranty status of your printer, and have it replace by them. If the warranty is already expired, you can send the printer to the nearest service center for repair.
Posted on Nov 03, 2011
Have lines on my pictures
First make sure you have a cartridge that is full.
I suggest you use the printers " FUNCTION BUTTON" and select SETUP and then MAINTENANCE.and do a PRINT NOZZLE CHECK PATTERN or AUTO HEAD ALIGNMENT.
Nov 04, 2014 | HP Officejet Pro L7680 All-in-One...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
My Epson Artisan 810 prints horizonal light blue lines on all printed materials. How to remove the blue lines?
To resolve this issue, you need to print a nozzle check pattern and then determine if print head cleanning is need.
To print nozzle check, follow the steps below.
  1. Turn off the Artisan Series and your computer, if connected.
  2. Disconnect any connected USB cables.
  3. Load plain paper in the main tray.
  4. Press the On button to turn the Artisan 800 Series on again.
  5. Press Setup.
  6. Select Maintenance.
  7. Select Nozzle Check.
  8. Press Start.
  9. The Artisan Series begins printing the nozzle check pattern.
  10. If there are no gaps, select Finish Nozzle Check.
    If there are gaps, select Head Cleaning.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Oct 31, 2011 | Epson Artisan 800 All-In-One InkJet...
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
When printing a red line appears about every 8mm through the all of the page i am useing a epson rx630 fred
It means some nozzle not perfect. If you check nozzle, there is missing lines for some nozzle. Example : Print blue color ( 100% cyan + 100% magenta). If some point of cyan head is clog, the output will be shown that at some lines just show magenta. It repeated. Yous said every 8 mm, so, you must print it at best photo quality. If you have print at best photo quality, and lines still appear, it must some nozlle badly clog. Try do head cleaning, wait for 30 minutes. Check Nozzle.
Jun 25, 2009 | Epson Office Equipment & Supplies
Epson RX620 yellow lines/blocks on page
Try to print the nozzle check, and see what your out put is like.
If it is not giving you a regular pattern, then have the nozzle
replaced. Most times when the nozzle is clogged with ink, you
get such out-puts. So follow this steps.
How to print the nozzle check:
1. Press the Setup button.
2. Use the arrow buttons to select Nozzle Check, then press the OK button.
3. Confirm the message on the display, then press the OK button to print the Nozzle Check.
Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps
Nozzle check pattern with gaps
Apr 14, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Epson L800 - printer - color - ink-jet Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
