Need to change default password on Onity HT22
I have a Onity HT22. I bought it used, and need to reset the default password (compromised). Could i just create a new user with the highest access, and then delete operators, and reprogram new operators? Any help is much appreciated.
5 Suggested Answers
SOURCE: I forgot my Administrator Password
i had the exact same problem...i was told to go on safe mode...and so i did..then i reset the password settings and changed my admin...hope it works 4 u.
Posted on Mar 03, 2008
diddydaveh
  • 154 Answers
Hi, download the recovery tool here
http://ophcrack.sourceforge.net/download.php?type=ophcrack
Posted on Mar 03, 2009
the system administrator has set policies to prevent this installation
Posted on Sep 10, 2009
SOURCE: reset bios/cmos password
on the bottom of the vostro 1510 there is a large panel that covers the hard drive, wifi card, and cmos battery connector. remove the cover unplug the red and black wire connector and remove the battery. also make sure the system is unplugged from power. i waited about 5 mins and pushed and held the power button for about a min. after that plug the main battery in and test to see if your password has been removed
Posted on Jul 06, 2010
Need to change the password
Pull out the manual that came with the hardware. In there you will find the section on resetting passwords. If you can't manage that task yourself, find the telephone number for support and have them run you through the steps. It is best you have customer support assist you with this problem.
Jan 28, 2014 | Aruba Networks - 650-US - Aruba 650...
Change password
Default Password
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password.Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router Reset for most routers with a reset button on the rear panelWrite down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
All NETGEAR devices
Note This is not my copyright sorry -This answer is copied from some where
Nov 28, 2011 | NetGear WGR614 Wireless Router
Lost my password
  • Username = admin
This applies to:
  • All NETGEAR devices
Sep 20, 2011 | NetGear WGR614 Wireless Router
I bought a Belkin (Surf+) Wireless Router, but lost the Password Card befor installing. I need a sulotion please.
The defaults are:
Router Mode: 192.168.2.1
Access Point Mode: 192.168.2.254
Default admin password:
If you changed the password and did not keep it then you will have the hard reset the router. You can find a link to the users manual here:
If you did change the defaults then you will need to hard reset the router. Instructions are in the manual.
Jun 03, 2011 | Belkin (F5D7230-4) Router (587009)
I need my netgear password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Click here for video walk through example of how to reset the WGR614v9 router.
Resolution:
Here is a small video that shows you how:
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Good luck.
Mar 10, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Looking for a manual for the Onity ht22
link to onity manual file:///C:/Users/Pier%20Hotel/Downloads/HT28v3%202user-master-Final.pdf
Oct 07, 2010 | Computers & Internet
Forgot my password
Most of the NETGEAR devices have the following default username and password except ReadyNAS products and Fully Managed switches:
  • Username is always admin
  • Password is password or (for older devices) 1234
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | NetGear RangeMax WPN824 Router
Someone is using my password, so Yahoo tells me to
hey this is just a warning .... it doesnt mean that someone else is using your account..not only your account will get that warning..it is default for every use ...dont panic ..nothing will happen .... for changing the password , go to yahoo settings and type your new password and confirm it , satisfying the default rules for creating yahoo password..
Jun 08, 2009 | Yahoo Mail
Computers & Internet Logo
730 people viewed this question
David Payne
David Payne
