Question about Dryers
Replace belt on kenmore 500 series dryer approx 20 years old
Does anybody know where i can find a part for a dryer this old???????
  • Dryers Master
  • 8,220 Answers
That belt part number is 341241. Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way.Use the belt routing diagram found HERE.
Posted on Jan 18, 2009
Replace the belt, need diagram
I use Google Type the model number then Belt Diagram in should come up with that for you
Sep 16, 2014 | Kenmore 500 6952 Dryer
Kenmore dryer 500 series
Belt is worn or stretched or the right rear bearing is siezed. Change both if dryer is old.
Apr 24, 2014 | Dryers
My mother in law has a kenmore dryer that is 15 - 20 years old. It will start but the dru will not turn she says it does not have a broken belt
Verification of the belt in place would first need to be done, then check to see if the motor is running.
The belt could have jumped off
if the belt was replaced recently, It might not have been the right belt.
Oct 06, 2010 | Kenmore Dryers
Kenmore 500 series dryer won't start. Only 2.5 years old.
turn the drum with your hand,if it feels hard to move you could have something stuck in the blower wheel that is below the lint filter and behind the duct that the filter slides into or the belt could be jammed,if it moves try starting it it might start you could have a flat spot on the motor and most likely you'll need to replace it,if it'shumming it's the motor making the sound
Feb 14, 2010 | Kenmore Dryers
Kenmore Soft Dry,
Try popping the lid and inspect the belt. I did one for friend. On his when the belt broke, the dryer quit. It has a built in safety switch. Sorry don't know the series. His was 15 years old plus...
Sep 13, 2009 | Kenmore 63942 Dryer
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
Old (approx 30 years) gas dryer. It's been great.
The fron comes off. Two screws located toward the bottom front (where the front panel angles in) hold the front on. Then you need to remove the front bulkhead/duct work.
Putting the belt on the idler pulley is the trick. If you get this far and need more help, let me know.
Vic
May 09, 2009 | Dryers
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Dryers Logo
388 people viewed this question
Top Dryers Experts
