Flash msi RG60SE with DD-WRT - Computers & Internet
  • 15 Answers
SOURCE: 3rd party firmware broke my router!
did you check whether you have downloaded the correct firmware for your linksys???
Posted on Dec 04, 2007
Roynice152
  • 88 Answers
SOURCE: Wrt150n, Flashed with DD WRT.
You probably need to update a newer version of firmware. Here is a link for you.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Posted on Feb 13, 2009
anandg27
  • 1272 Answers
SOURCE: i cant seem to figure out what is the IP address
The default IP address for this router is 192.168.1.1
unless changed. If you want to be double sure then perform the steps below:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Default gateway here is the IP address of your router
Hope this helps.
Posted on Sep 24, 2009
SOURCE: My linksys wrt54G v6 router has a blinking power
Understand that what you are trying to do, may permanently turn that router into a piece of trash. Firmware upgrades are hit and miss, and sometimes even doing everything correctly will result in a "Bricked" router. A bricked router is one that is about as useful to a computer as a brick. Proceed at your OWN RISK!
Read all directions BEFORE you try anything! First D/L the correct firmware for your router. Then D/L TFTP.EXE from the DD-WRT site. Put these files right on the desktop where you can find them and unzip the firmware. (I am assuming you are running Windows XP)
Now connect your router to the computer you are using with an Ethernet cable and plug in the power. DO NOT TRY THIS VIA WIRELESS!! Then you need to set your computer to a fixed IP address, Open your network connections (control panel - Network Connections) right click your local area connection and select properties. Highlight Internet Protocol(TCP/IP) and again select properties. Under the General Tab select "Use the following IP address" enter 192.168.1.99 Under Subnet mask enter 255.255.255.0 Click OK and wait for the TCP/IP connection to be established. The router first must be reset to the factory default configuration BEFORE you flash it.
Resetting the router means, with the router plugged in to a power source hold down the reset button (on the back of the router) for 30 seconds, then pull the power but continue holding the reset button for another 30 seconds. Then WHILE STILL HOLDING THE RESET BUTTON, plug the power back in and hold it for another 30 seconds. Now you can let the button go and allow the router to reboot.
If you still have only the power light blinking, try pinging the router. Open a command prompt, (Start RUN CMD [Enter]) and type PING -t 192.168.1.1 Leave this window open and dbl-click the TFTP.exe program. There are three empty boxes in the TFTP program. Enter the IP address of the router in the server box (192.168.1.1) enter ADMIN (all lower case) in the password box and click the dots next to the file box, browse to your desktop and select the firmware image you downloaded (.BIN)
Now if your ping command is only returning "Request Timed Out" try resetting the router again only this time watch the ping window for a response from the router. If you get a response, immediately click "upgrade" on the TFTP window. If all goes well you should get an "Upgrade Successful" message. This step is important!! RESET THE ROUTER again after waiting 10 minutes. Now if the router was not initially reset to the factory default configuration before someone tried to upgrade the firmware, it is possible that the router is hanging while it tries to boot and the firmware image was corrupted. If that is the case then you will need to read the DD-WRT Wiki under "Bricked Router". Good Luck!!
Posted on Dec 11, 2009
  • 1027 Answers
SOURCE: msi 108 wireless router
on this page you can read the user manual:
http://www.scribd.com/doc/33684983/MSI-RG60SE
The default IP address is 192.168.1.1
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Posted on Apr 10, 2011
I can't turn wps off
Open a Web browser, then type IP address into the address bar then Press enter.
->Login with username and password.
->Click Wi-Fi Protected Setup under the Wireless category.
->Click Disabled, then click Apply Changes to save and apply the settings.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Mar 14, 2013 | Computers & Internet
Please advise where to download the firmware for MSI router RG60se ? thanks
http://faenl.msi.com/index.php?dir=Networking/RG60SE/
Enter the firmware folder, then click on the rg60se-up.rar.
Jun 24, 2011 | Computers & Internet
Msi 108 wireless router rg60se ip adress needed
Apr 10, 2011 | MSI Computers & Internet
Just bought this Router ASUS RT N16. I upgraded the firmware to DD-WRT. Then upgraded to Tomato firmware following instructions found on the net. Router worked fine with DD-WRT but when I did the install...
If the device is dead in the water as a result of flashing the firmware - then I'd bring it back for either my money back or even exchange. I'd explain that during a firmware update, it became unresponsive. That's it.
I'd flash the replacement to DD-WRT firmware for your particular router again. Make sure you've got the right firmware file for your router's hardware revision too. I'd hold off on flashing to Tomato. (I use DD-WRT to perform wireless bridging w/ two Linky WRT54Gs and haven't had to do a thing to them in 3 years now - I must admit that I'm not familiar with Tomato). There's got to be an issue with the Tomato upgrade procedure you followed, firmware file or a mismatch on hardware revision of the router. I'd want to find out what that problem is before attempting it again. I doubt the store would be very understanding if you showed up with yet another dead router.
I hope this helps & good luck! Please rate my reply. Thank you.
Apr 04, 2011 | Computers & Internet
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Repeater router responds with 'Address not found...'
You need to start from scratch.
Whenever you need answers they can be found here -
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=785382853553ee7844cfab78da0607db
But best to start with the Wili - http://www.dd-wrt.com/wiki/index.php/Installation
And here is your get out of jail card -
http://www.dd-wrt.com/wiki/index.php?title=Recover_from_a_Bad_Flash
If you have to resort to the hard method of recovery, be careful.
I have only ever permanently killed one router - doing this - http://voidmain.is-a-geek.net/redhat/wrt54g_revival.html
You will first need to establish which model router you have. Then you will (assuming you want to use DD-WRT firmware) need to flash a micro or mini firmware. Then you flash again, using the standard.
There are many users worldwide using your WRT54G and GL routers with other than standard firmware, me included. I manage a network of 9 routers running DD-WRT V23SP2 standard.
Don't give up, and when it says to leave it 30 seconds (or 2 minutes) DO! Be patient...
Apr 06, 2009 | Linksys Wireless-G WRT54G Router
Wrt150n dd-wrt firmware slow loading pages
First off thanks for using fixya.com
Second, I too am a dd-wrt user and found a similar problem when using dd-wrt with my IPCOP. You may want to go into the "Security" section of your dd-wrt and disable any fire walling or access-restrictions. Since you are already running zonealarm. Or remove zonealarm if you plan to use dd-wrt as your firewall.
Running multiple firewalls will slow down your network/Internet traffic.
Hope this helps you out.
Jei
Dec 15, 2008 | Linksys Wireless-N WRT150N Router
Router to use as relay.
Linksys WRT54GL with DD-WRT firmware. Now, DD-WRT will void the warranty, but it has been incredible for my uses when configuring WDS. A the WRT54GS has also been said to be an excellent router, but I cannot say.
Dec 22, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
536 people viewed this question
David Payne
David Payne
