Question about Garden
What fuel do i use for a scott bonnar sx4000 - Garden
3 Suggested Answers
huffman49
  • 235 Answers
SOURCE: I have a scott bonnar reel mower & a fine
it goes in the same hole as the throttle linkage is
Posted on Apr 04, 2010
Testimonial: "thanks, it works again."
SOURCE: scott bonnar lawn mower service manual model 520...
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
Posted on Sep 21, 2010
Lawn catcher for a scott bonnar 16 ins
can be sourced
a mower shop
ebay
scott bonnar mower parts list ?
Oct 30, 2016 | Garden
How much oil do you put in a scott bonnar 45 lawn mower
as much as it takes to put the oil level on the full mark of the dip stick
some where around 250 mils
Jun 15, 2015 | Garden
Scott bonnar 45 lawner mower B & S engine oil capacity
Should be just under a quart of oil. Fill to the top of the oil fill hole then stop.
Replacing the pull cord on a scott bonnar sx4000
Home Depot and other home improvement stores sell universal replacement pull cords for less that 4 dollars. Instructions are on the bag. Look at the screen covering the pull cord to see if it is bolted on or pop riveted. If it's pop riveted you'll have to drill out the rivets to get at the cord. Have a pop rivet tool and the proper sized rivets ready to re install the cover
Sep 23, 2014 | Garden
I have A Scott Bonner lawn mower ,high performance,overhead cam, SX 4000, 4 stroke.I am finding it very difficult to start the cold mower every time I go to mow the lawn.It takes me about half an hour of...
Hi and welcome to FixYa, I am Kelly.
The symptoms you describe are typical of debris in the fuel bowl of the carb. I am going to assume for the moment that it is a similar to a Briggs and Stratton engine. Engine model type and serial information is what we work with to resolve engine problems regardless of the mower brand. I note you said it was a Scott Bonner SX4000 engine. I am also assuming that you have the 18 inch GreenKeeper like this one:
http://www.rovermowers.co.nz/www/rover/Home.nsf/13a851504c93cb754a257821000cfc6b/$FILE/28045.pdf
I do not have access to Scott Bonner Engine parts or technical data but if you clean out the fuel float bowl and it is still hard to start then the choke function of the engine is not working. Your engine has a "Bowl drain" screw on the bottom of the carb float bowl for removing carb debris or water in addition to a bowl nut.
Most likely due to the throttle cable needing and adjustment so that the choke is closed when choke is selected. Adjustment of the throttle cable is as simple as losening the clamp screw (Do NOT remove it) on the side of the carb throttle control and moving the throttle to STOP then re-tightening the clamp retaining screw. This should allow your choke to move full closed when selected. You may have to experiment with full throttle and STOP throttle control positions with the clamp screw loose but not removed to see which position will give you full throttle, choke and STOP. After each adjustment you MUST tighten the clamp screw to test the throttle cable travel on the the throttle plate. Beleive it or not... the person that assemble the mower made the intial throttle adjustment. It may have never been tested before you got the mower.
If you still have problems.... this is the brief way to start an engine that has choke problems. Remove the spark plug and squirt a splash of gas into the spark plug hole and then re-install the spark plug. Just don't over-do the splash of gas and if your messy wipe off the excess so you do not start a fire. (This method always works but you occasionally foul a spark plug with too much gas)
Thanks for choosing FixYa,
Kelly
Feb 01, 2011 | Garden
Scott bonnar lawn mower service manual model 520
May 17, 2010 | Garden
Fix scott bonnar lawnmower Prisma 37 model
Start by replacing the fuel filter and connecting hose at the leak point. It is important to use "fuel hose" and fuel hose clips - which are different to standard hose clamps.
If you have problems with mice - use a steel braided fuel hose - as they can't chew through these ! -
http://www.vehicle-wiring-products.eu/VWP-onlinestore/hoses/hoses.php
May 14, 2009 | THQ The Lawnmower Man
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
