IGO TV SMPS Circuit diagram
SMPS VOLT 95 OUT PUT
2 Suggested Answers
timblodgett
  • 691 Answers
SOURCE: Where can I get Onida Igo CRT TV 29" circuit diagram
Usually there are schematics pasted inside the casing. If the is a sub-compartment(ie. power supply, signal shield required areas) the schematic for the components in the compartment will be pasted to the inside wall & not usually visible until you open it. Hope you find this helpful, good luck.
Posted on May 15, 2016
I am trying to get the manual for my hisense 32H3E tv please help I am trying to to see my power board lay _out as show in the picture
Hi Charles
The SMPS section circuit is a built in part of the main board. Just see the location. I've marked it. If you're in search for the SMPS circuit diagram, and you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Circuit diagrams of SMPS section of many popular brand devices are given.
26391719-r0wg02at1b5uk5b5kqg3kgh2-3-0.jpg 26391719-r0wg02at1b5uk5b5kqg3kgh2-3-2.jpg
Dec 09, 2016 | Hisense Televison & Video
Lg tv strw6554a smps may I get the circuit diagrame .This is ultra slim CRT tv 21"
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the STR number of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Sep 30, 2016 | LG Televison & Video
What is the vertical ic number of onida igo ultraslim CI21JST200B colour tv ?
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Jun 10, 2016 | Televison & Video
May 15, 2016 | Televison & Video
What is the # of ic part of isolated area of polytron tv?
You're asking about the number of IC used in its smps [POWER REGULATOR] section circuit, I assume. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to SMPS [Power supply regulator] section to many popular brand TVs and other devices are given. You can fetch details there.
Aug 18, 2015 | Televison & Video
Why my hp designjet 500 smps has high voltage than normal
check power supply and if voltage are good change Electronic module its damaged. this voltage what you are write not normal!
May 21, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Smps not working
http://www.itwinkle.com/hp57posub.html
Nothing special about that Power Supply except for the PRICE!
It's just a regular ATX SMPS with a 575 Watt maximum rate wattage, and an 8-pin EPS +12 Volt power cable.
The HP part number is HP 405349-001
I just THOUGHT the above model was expensive,
http://www.sears.com/hp-405349-001-hp-575watt-power-supply-for-workstation/p-SP101A9790S5492818201P
Uses one 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
One 8-pin EPS +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
[NOTE*
NOT to be confused with the 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
Yellow wires are 12 Volt wires. Black wires are Ground (Negative) wires.
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
The 8-pin PCI Express power cable has THREE 12 Volt wires ]
I believe 4 SATA power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
,and a few 4-pin Peripheral power cables, ('Molex'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Power Supply case dimensions are approximately
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.40mm Wide, 139.70 Long, and 88.89mm in Height )
36 Amps combined for the two 12 Volt power rails.
(12V1 = 18 Amps, 12V2 = 18 Amps)
This is an example of a replacement SMPS,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899124&CatId=1483
I'm running one of these right now in a Dell Optiplex 745
Yes, even though the power cabling noted on the Tigerdirect ad is erroneous, it DOES have an 8-pin EPS +12 Volt power cable.
One 24-pin ATX main power cable
Four 4-pin Peripheral power cables
Six SATA power cables
One Small 4-pin Peripheral power cable. (Used for a Floppy Drive, or a Card Reader)
Two 12 Volt power rails. 12V1 = 23 Amps, 12V2 = 20 Amps
Combined = 43 Amps on the 12 Volt power rail.
Repair?
Due to the possible electrocution hazard, I don't post info on repair.
I will state;
The capacitors need to be PROPERLY discharged, before attempting to work on the unit.
The Radial Aluminum Electrolytic Capacitors are the weakest link.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Computers & Internet
LG VCR power up problem
check smps volt +12v, -12v, 5v,3.3v, -22v.mast be have +12v, -12v, 5v.if not change or" connect extranal smps.
May 30, 2012 | LG Televison & Video
Red or green light wont come on on my sharp 42 inc
Possible failure of the main power supply which is a SMPS unit. So please check this link for tips to repair. If the smps is working then the processor section must be checked specially for the +5 volt to the IC. If absent check the LT side of the SMPS or the 5 volt regulator.
check this link :
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Dec 01, 2011 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
