Question about Eizo I-Station Networking Hub
My hp pavilion tx1000series won't boot even at bios
My laptop won't load vista. it turns on with black screen and nothing else, even at BIOS won't load, its just black screen and led light. The laptop doesn't even sound like to do anything. the only you can hear is the fan's turning. i restart and nothings happen.
  • Anonymous Feb 28, 2009
    I have the same problem. Anyone knows how to fix this?
    Problem Solver:
  • 17 Answers
EXTREMELY common failure in the TX1000 line. Problem is the mainboard, part# 441097-001. From HP it should only be about $200 on exchange. DO NOT get this part anywhere else, as the OTHER common failure for this model is the wifi goes out.
I do about 10 of these TX's per day, no im not kidding, and i promise you HP has the most stable parts source around for this.
-Sy
Posted on Jun 11, 2009
    Problem Solver:
  • 13 Answers
Gpu is battered
Posted on Jul 24, 2010
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Jul 07, 2010 | HP Pavilion dv6000z Notebook
My HP Pavilion Dv6700 turns on but nothing on the screen as in its black, BIOS do not show. Please help!
Looks like the post itself fails on the system from what you have told here. Its easy to reset the bios. Download the actual bios flash program on a completely formated usb drive. Fix the usb on your laptop and keep fn+esc keys pressed and switch on the laptop. It will rewrite the bios and once rebooted the system should work. Good Luck.
May 05, 2010 | HP Pavilion DV6700Z Notebook
HP pavilion dv2025nr do not boot
Hi
please press DEL to set the bios settings then choose the Bios set up! then click the bootable device SCSI.
Thanks!
Jun 07, 2009 | HP Pavilion dv2000t Notebook
My HP Pavilion DV9000 is having boot up problem
hi
this is nothing to do with system crash.
> Take out the battery and the adapter from the notebook hold the power button for 30 sec
> Power on - ASAP tap on F10 - There if you are using vista press F9 to load the bios defaults and press F10 save and exit
With regards
Apr 12, 2009 | HP Pavilion dv9000z Notebook
Hp dv2000 startup issue
load bios defaults from the bios menu. it could help!
Mar 02, 2009 | HP Pavilion dv6000z Notebook
Lights turn on when starting up but screen stays black
Reboot and hold down the delete key to open the bios. Reset the bios to default settings then see if that fixes it. If not you may have to reload the computer to its factory load.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
Eizo I-Station Networking Hub Logo
226 people viewed this question
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
