Question about Toys
Gyro lite U803 instructions
Can not seem to progam the remote with the helicopter. It is charged, new batteries in remote. Light on remote keeps flahing
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
SOURCE: I Just bought a Syma
You need to assign the remote to the copter, turn on copter then remote, push forward on throttle then back, light on remote will stop flashing and remain static, there we go ready to fly have fun great machine.....
Posted on Sep 16, 2010
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
Posted on Dec 02, 2010
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: I can't seem to charge
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
Posted on Mar 09, 2011
Syma S033G Helicopter does not lift off then stops
too much power,get a 7.4 volt battery and charge it to 7.4 volts,any more kills battery
Apr 16, 2015 | Syma S033G REMOTE CONTROLLED 3.5 CHANNELS...
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Hello i just bought a s032g from dealextreme 032 does not start up react to transmitter is zero i folowd the start protocol but noting anny ideas thanks
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Aug 13, 2011 | SYMA Toys industrial Syma S032 Ready to...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
4) Power on remote.
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
4) Power on remote.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Dec 26, 2008 | Air Hogs Havoc Heli Helicopters
Toys Logo
69 people viewed this question
Top Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
