Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster Garage Door Open Gears destruction
The motor shaft auger gear keeps eating the drive shaft nylon gear. I have replaced the shaft/gear assembly and motor shaft bearings in addition to adjusting both the lift and force settings. Why does it keep doing this?
  • 118 Answers
Your door is not properly balanced
Posted on Jan 18, 2009
My motor just hums, but doesn't turn gears.
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is just in front of the motor. It will be obvious if it is bad. Is your door stuck in the open position?
Aug 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster will open three inches and then go back down? Any suggestios
Check your door springs and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but door does not open on my craftsman 1/2 h.p. Garage door opener
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is most likely stripped.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can hear the motor "working" but the chain is not moving and so door will not open?
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and I'm sure you will find it is stripped. The part number is 41A2817 and is available at any door opener service company. It comes with instructions.
Mar 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 HP Garage Door opener won't open or close. Has been working fine until I pulled out this morning. The door will move freely if I disengage from opener. Went up ladder to see chain not...
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Feb 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door will not open nor close. motor works, but chain does not move on the gears.
Your drive gear is bad. It is a white nylon gear just in front of the motor. It will be obvious if you remove the cover.
Dec 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs...chain doesn't move and door will not open
Many of these openers use nylon gears and can easily be stripped. Remove the cover to the main motor drive and see if the gears are stripped.
Jul 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Won't Open
When mine did this, it was because the nylon gears that drive the chain had stripped. My wife had to live without the opener for a week or more, but I was able to find a new gear kit online and replace the damaged gears. It wasn't difficult.
The other option is to buy a new opener.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
173 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
