Question about Pool & Spa
Instructions for filter set up for driclad fast set pool
2 Suggested Answers
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
Replacement hose adapter
Where is this Victoria located? That will make a big difference on what hose adapters you can get. You might also be able to order online.
Elisa Jed ' http://www.gilbert-pool-service-repair.com
Mar 01, 2014 | Intex Pool & Spa
I need a instructions manual for hooking up the pump to my intex above grownd pool
Go to www.intexcorp.com. On the home page, you'll have to chose your location/country. From there, click on " Need replacement parts or Accessories for Intex Products", under Consumer Info heading. Near bottom of page on right side. From there, click on " Instructional set videos and manuals, on right side of screen. Then click " Product set up manuals". From there, chose the type of filter you have and the instruction manual will open. Or you can click on the product set up video to nsee how it's set up!
Jun 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I have lost my instruction manual for the filter set up on my Intex Summer Escapes easy set 8' pool. Is there a site i can go to to review filter set up. Everything else is super easy. I just want to...
I couldn't find an exact guide online, but this site has a lot of resources that may be able to help you out. Good luck!
http://www.ehow.com/pool-filter-instructions/
May 06, 2011 | Computers & Internet
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Intex filter model 633 with no instruction manual on how to set i
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Jun 14, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
May 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool & Spa Logo
679 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
