Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan and surface light of microwave GE out of order
I was replacing light bulb in our spacemaker XL microwave model: JVM 1331WW 005. I guess the light holder was loose and made a short circuit. Now when I push vent and light buttons, I hear a click sound, but they don't work. It seems there should be some fuse. I checked fuse inside and it was fine. Could you give us some tips? Thanks.
-Seyed
  • cpjjr Jan 27, 2009
    When replacing the light there was a short cricuit now the fan stays on and won't go off
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 18, 2009
My microwave just stopped working it does'nt do
do you know why did it not work ?you check it .and you can take it to fix .
home light bulbs
May 03, 2012 | GE Microwave Ovens
Oven is not heating at all. I also smelled burnt plastic. Model is GE Spacemaker XL JVM 1440.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 02, 2010 | GE JVM1440 Microwave Oven
Wher do I get the two pin bulbs for the
Hi there, I checked this very quickly for you, and you should be able to get this at your nearest appliance parts store. It's not a rare lamp, so you should try this first. Otherwise, you can go online and order it. Whereas, if you're not in a hurry, it would run you about $15.00 total (including shipping and handling). It's about a $5.00 part otherwise. Just bring the lamp, or all the information you have here - and that'll help the clerk. I believe this a 20 watt lamp also. Anyway, I hope this helps you. Good Luck, and feel free to contact me if you have any further electrical or lighting problems. - Jim
May 22, 2010 | GE XL1800 1100 Watts Microwave Oven
Our GE Spacemaker xl JVM 1630 has died and needs to be replaced. Who in Hoover, AL or Pelham, AL has one that will fit and will have the lights/fan on the bottom?
You should be able to contact GE and see if they have a "drop-in" replacement for your model.
GE Customer Service is here.
Quite often, microwaves are pretty easy for the DIYer to fix. Feel free to contact me with your full model and symptoms for free help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Nov 28, 2009 | GE JVM1630 Microwave Oven
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker XL Microwave Oven JVM 1650/1651
the microwave is running even though your not pressing any buttons? it would be a control board problem,. could be main relay contacts welded together.
Feb 19, 2008 | Microwave Ovens
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
177 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
