Question about Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite a215-s7437 will not boot at all - black screen
I have had this laptop for a little over a year and about a month ago I started getting the mysterious black screen. I would hold down the power button to shut it down and then when I restarted it, it would start fine. About 2 weeks ago, the shut-down and restart method stopped working, so I would shut it down, remove the battery, replace it and then it would restart. I did some searching online and found a couple of places that said I needed to update the BIOS. So went to the Toshiba site and downloaded the BIOS update. At the end of the update, it shut down. When I tried to restart it, I got NOTHING! I've tried removing the battery, unplugging it, etc.and still nothing. I got out the master recovery CD and tried it. The CD drive would spin for a second when I tried to turn on the system and held 'C' but still I just had a black screen.
My plug in light is on, the power light comes on, and the battery light is on, but the hard drive light NEVER comes on and I can't hear it 'churning'. However the fan is always on if it's plugged in or if the battery is in.
Does anyone have ANY suggestions? I've searched everywhere and found nothing to help.
Thanks,
Julie
  • 114 Answers
Sounds like you have two problems to me.
1) The lamp (CCFL) doesn't always light (which can be usually the lamp or the inverter that drives the lamp) which causes the screen to go dark. You can prove this by shining a strong light on the screen (like a flashlight) and you should see an image faintly.
2) It sounds like the BIOS update didn't go well. Meaning it now refuses to boot and it is in a state we call bricked.
I hate to tell you this, but I think it is time for some professional help. If it is still under warrantee, I would take it in. If not, you might be looking at a bill for $300 or more. Sorry. :(
Posted on Jan 18, 2009
    Scholar:
  • 170 Answers
I think I have the answer you are looking for.  Plug your laptop into an external monitor. Once you do that you need to set your power/performance settings to high performance. It is  turning the display off because some of the processing needed to display images are not available when not in high performance. I hope this helps, let me know how you make out,
Good luck.
Toshiba C655s5120 black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 13, 2012 | Toshiba Satellite A215-S7437 Notebook
I have a toshiba A215-S7437 and i get the error message read disk error when trying to boot up
A disk error is a fatal error on the hard drive, SMART monitoring will show you this in the BIOS, restoring to factory settings will not cure it.
You need to get a new hard disk and reinstall your OS
Apr 25, 2012 | Toshiba Satellite A215-S7437 Notebook
Diagrams for Toshiba A215 S7437
The Toshiba Satellite A215-S7437 Notebook PC, is one of the Satellite A215 series of Notebook PC's. It is a fancier version of the A200 series.
Pictorial guide to disassembly of the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
[Note* Page 2, 3, and 4, are listed at the top, and bottom of the page.
In white; Page1::Page2::Page3::Page4::Find another model ]
Service Manual for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main heading - Toshiba, go down to the subheading -
Satellite A10. (A10 in blue)
Go across, and click on A215. (In blue)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 }, it may take up to 30 seconds before the first page comes up.
The motherboard diagram follows this diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The CPU is an AMD Athlon 64 X2 TL-58, (Turion Core ), mobile Processor,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29_2
Processor has two processor cores that can operate up to 1900MegaHertz, or also stated as 1.9GigaHertz.
(1900MHz/1.9GHz)
Does Not mean a total of 3.8GHz.
Total is still 1.9GHz. It's just two processor cores teaming up on the same task.
Chip and Chipset denote I.C.
Integrated Circuit.
The motherboard chipset is an ATI RX-690 (Southbridge chip is ATI SB600 )
http://en.wikipedia.org/wiki/AMD_690_chipset_series
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite A215-S7437 Notebook
Toshiba A215 doest boot at all( screen empty) tried removing the CMOS battery but no change at the moment
that happened with me once , i solved it by separating the laptops battery for 8 Hrs to let the mother board discharge and cleaning the mother board and memory slots and cpu socket with the air blower.
good luck
Feb 19, 2010 | Toshiba Satellite A215-S7437 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite A215-S7437 Laptop Password Problem?
You should first check if the pasword is set on the hard drive. If so you can simply change the hard drive and it will then boot and ask for the operating system disk. If not, you should try by removing the cmos battery and waiting at least 10 minutes. (this works on older laptops) however, the laptop's power suply cable and battery should be removed prior to performing this procedure.
Jan 10, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
237 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
