Question about Toys
Aero Star UJ4801 top main blade is not spinning
The top balance bar will not spin when I power up the helicopter.
SOURCE: i have an apache 3 channel helicopter.the top
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
SOURCE: crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
SOURCE: remove and replace balance bar?
Were you able to find a replacement balance bar? I broke mine and can't find one? Thanks!
Posted on Dec 22, 2010
  • 3 Answers
SOURCE: I cHarged the helicopter and
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Posted on Dec 25, 2010
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
My silver bullet helicopter wont take off, the top blade is spinning but the bottom one isnt
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Jan 01, 2014 | Shuttle 9094 Emax Remote Control...
Volitation helicopter just spins to the left on ground and will not lift off seems top blades are spinning much faster then bottom
If one blade is spinning faster than another, then the helicopter won't lift off. The first thing to check is the gears driving the blade shafts. It could be that one of the gears is not set properly, or there is something caught near the shaft. Pet hair can often wrap around the shaft and cause drag. If the gears appear to be in the correct positions, and meshing with the pinions (small gears) on the motors, and there is nothing wrapped around the shaft, such as hair, I would slowly increase power and see if both motors start spinning at the same time. If they don't, there could be a problem with the motor, or the controller board. If this is the case, it may be repairable, but might be just as cheap to replace the whole helicopter.
Hope this helps!
Aug 29, 2013 | xheli 9053 Outdoor Volitation Metal...
Top blade wont spin help.
the top blade should not spin unless the main rotors are turning as this gives the copter forward and sideways movment it should be secured with a small grub screw to the main shaft
hope this helps
Aug 08, 2011 | RC Remote Control Rc Helicopter
We have a GYROS S107G and when we lift off the hellicopter immediately starts to lose control and the balancing bar seems to hit the upper blades causing it to crash. Also, the side braces which hold the...
The top of the main shaft is probably broken. There are 2 pins that hold the "head" for the main blades straight and are probably sheared off. This is causing the balance bar to hit the blades and cause it to crash. You could try the crash kit here: http://www.helipal.com/spare-part_v-max-parts_syma-s107.html
Jan 09, 2011 | xheli Syma S031 Outdoor RC Helicopter
I have Brookstones silver bullet u control helicopter and have a problem. I crashed it, and when I went to fly it again it seems like the bottom blade is hit off the tail of the helicopter. Do I just...
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Dec 27, 2010 | Shuttle 9094 Emax Remote Control...
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
Sep 04, 2009 | Apache RC Mini Helicopter AH-64
Heli max hicro helicopter just keeps spinning in circles
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Toys Logo
19 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
