Question about Miele Dishwashers
I've just installed a Miele 5500SCU Dishwasher and the springs that support the door cant be adjusted far enough to take the weight of the door, does anyone have any suggestions?
I have already adjusted the spring tension fully on both sides of the unit as per the instructions but it doesn't feel like there is any resistance there and the door free falls. Could the springs have fallen off and is there an easy way to check?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 14 Answers
If the dishwasher is brand new, then there is an issue with the configuration of the springs, i.e not mounted correctly. A factory dishwasher door should not need to be adjusted. However if it is older, it is possible that the springs came off, in which case they can be seen from the underside of the dishwasher and by a panel that unscrews on the bottom of the door. Make sure the springs are there.
Posted on Dec 30, 2012
  • 209 Answers
SOURCE: Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
Master_Tech
  • 770 Answers
SOURCE: dishwasher door, too much spring
YES after you have the panel installed it will open and close much better the factory sets the springs on your model tight so when the panel is installed it can weight down the door after the panel is install you may have to readjust them tighter again
Posted on Feb 23, 2008
SOURCE: Door falls open
I have had this issue TWICE now on a three year old dishwasher, and Sears charges you $150.+ to fix it. It is quite simple to fix, there is a special part that has all the pieces attached to it, except for the spring. You will have to remove the screws that are holding your dishwasher under the counter. This could be behind the rubber on the sides. I had to remove a gray plastic circle piece on the inside to see the screw (it pops right out, don't loose it!). Pull out the machine enough to see the out side- side. You will see a (plastic) white roller, string(rope), and a piece that attaches to the dishwasher. There is a number on the white plastic piece that looks like a L (it just slides out). Thess pieces are called the Dishwasher Door Balance Link. You will need to order these pieces, they are all inclusive, and come for both sides of the door, at a whopping price of $15.00. VERY simple to install. Attach one end to the spring, line up in roller then attach to the dishwasher. It is easier to look at it and follow what is on the dishwasher than me clearly explaining it. I feel that paying $1000.00 dollars for a dishwasher would warrant using metal pieces instead of substandard plastic, for this application. These door are very Heavy and like I have said I have replaced them twice with a waiting time of three weeks for the repair man. Please try it, you can do it.
Posted on Dec 31, 2007
  • 409 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
docjohn174
  • 943 Answers
SOURCE: I assume the spring in
Hi Thanks For The Question. You Have To Disconnect And Pull Out, From Counter. Only Way. Thanks .The Appliance Doc
Posted on Oct 03, 2008
How do I fix or replace the door spring in a Miele G6892 dishwasher?
Step 1: Get Access to the Door Spring Remove the lower panel under the door. Normally, two screws keep the panel in place. These screws are located on top of or below the panel. There are cases wherein you have to initially open the dishwasher door to be able to remove the screws. The door should then be closed in order to remove the panel.
Step 2: Remove Springs To remove the springs, the hook of the spring should be lifted from the anchor point. Use your fingers to do so. If there is a large amount of tension, it's best to use a screwdriver or pliars. Position the shaft under the hook and then pull it down. After pulling down, try lifting the anchor. To make things easier, try locating a leverage point. This should help the screwdriver force the spring out. Be certain to remove the spring from all of its anchor points.
Step 3: Installation of New Springs To install a new spring, you initially have to deal with the positioning of the lower spring hook. It should be placed within the first hole. Take note of the adjustment bracket when doing this. Follow the previous set up. If the spring needs more tension, try positioning the spring hook further towards the back of the adjustment bracket. The end of the spring for the counter balance of the door should be mounted on the door support. Find the slot on the support. Replace all covers and door panels. Test the door to check for any problems.
Jul 16, 2016 | Miele Dishwashers
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
The door wont shut properly
see this causes and use the common sense.God bless you
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
How to install new door spring on portable dishwasher
Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Replacement spring (optional)
  1. Turn off the power to your Kenmore dishwasher before attempting any repairs. If you have a portable Kenmore dishwasher, you can just unplug the power cord from the wall. Built-in dishwashers are hard-wired into the cabinet, so you will have to turn off the breaker switch at the home's circuit breaker box to cut the power.
  2. 2 Remove the screws that hold the kickplate onto the lower front of the Kenmore dishwasher. Take the kickplate off to access the door springs.
  3. Check the door springs to make sure they have not come loose from the door support or the adjustment holes on the dishwasher. Re-attach any ends that have slipped off their connections.
  4. Replace the springs if they are connected at both ends but still do not have enough tension to support the weight of the door. Once a Kenmore dishwasher door spring is stretched out, it cannot be restored to its original condition. Unhook one end of the old spring from the adjustment hole. Unhook the other end from the door support and discard the spring. Insert one end of the replacement spring into the adjustment hole and the other end into the hook on the door support.
  5. Open and close the door a few times to make sure the spring is now working properly. The door should not bounce up and down or sag on the hinges when it is in the open position.
  6. Restore power to your Kenmore dishwasher by plugging it back in or turning on the switch at the home's circuit breaker panel.
Dec 21, 2010 | Maytag Dishwashers
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher door, too much spring
Feb 23, 2008 | Dishwashers
Door problem
on my machine there is a torx screw at the top left hand side. You need to open the door to see the screw which sits behind the off-white flange (look for a hole in the flange).
Oct 22, 2007 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
471 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
