Question about Frigidaire Dishwashers
Dishwasher not filling with water
My sink was backed up so my dishwasher was unable to drain. I had the drain unclogged, and so I needed to run the dishwasher and now it will not fill with water. It's making the cycle sound but no water. Do the dishwashers have a water pump safety switch that needs to be reset? I unplugged it and let it sit for awhile anything else? it's approx 5 years old, built in, model #fdbl960bb0 serial # th24453453
  • 640 Answers
Look in the dishwasher theres a little float plastic and round take your hand and pick iu and drop it if that float stuck up when dishwaser had water,,it will need a little help dropping back in slot...onthejob
Posted on Jan 18, 2009
THe dishwasher is not draining and runs out onto the floor. What should we do?
Drain is plugged between the sink and dishwasher. It has to be unclogged. best advice call a plumber. other tricks fill up the sink with water and use a plunger to pull the sludge through.
Feb 25, 2014 | Fagor 24 in. FI-48W Dishwasher
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux dishwasher overflows
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Bosch dishwasher SHX46 won't fill with water
My model is actually a SHX46 but I was able to piece together some advice off of this site. This is what I did. I removed the toe plate and then I soaked up all the water that I could out of the white pan at the bottom. Then I unhooked the water supply line so that I could pull the dishwasher out. Once I got it out, I tipped it forward to drain out the rest of the water. I then unhooked the drain line that was connected to the disposal and cleaned it out with a "Snake line" I then hooked everything back up and it worked. Thanks so much for this website, I know it saved me a ton of $$$$$$$$$.
Jan 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Dishwashers Logo
165 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
