I have an American Standard heat pump. My heat strips in my home are automatically turning on immediately when the heat pump starts. It heats the house up very quickly, but with the strips turning on immediately it is defeating the purpose of the heat pump savings on my electric bill. My electrical meter runs very very fast as soon as the heat pump turns on. I know this is not how the heat pump is supposed to operate. I am using a lot more electricity than I should be using. Can you tell me how to solve this? Can I adjust something on the thermostat myself? Thanks.
    Top Expert:
  • Heating & Co... Master
  • 48,384 Answers
Could be more to the problem
call a technician to diagnose the problem and quote
Posted on Apr 27, 2017
  • 1,658 Answers
First be sure you are wired using the heat pump letters inside the tstat. Then check the settings on the tstat. Be sure it is setup for a heat pump with backup electric heat. Try the system in cooling and see if it is cooling properly (15 to 20 degree temp difference between return and supply) or try removing the white wire from the tstat and capping safely inside and see if that keeps the heat strips off. But, as stated, there are a number of reasons why this could be happening, you need a professional.
5 Suggested Answers
  • 10 Answers
SOURCE: electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Posted on Jan 04, 2008
  • 144 Answers
SOURCE: Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Posted on Feb 19, 2009
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Posted on Mar 26, 2009
  • 234 Answers
SOURCE: Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Posted on Apr 07, 2009
Heat works until thermostat calls for aux heat, then blower shuts off with outside unit still running.
Some blowers shut off depending on the system. Do you have electric hest strips inside? If not the blower will shut off. The outdoor fan should not be running if in defrost mode. If you have heat strips then you likely have low voltage wiring crossed
Dec 16, 2016 | American Standard Heating & Cooling
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
American standard error code 158
thermostat error codes for an american standard ... - AllExperts > ... > Heating, Air Conditioning, Fridge, HVAC
Aug 22, 2010 - programmable thermostat, error codes, american standard: James, I am not familiar with that stat set up,short of goggle/yahoo the codes may ...
Jul 24, 2015 | American Standard 5000 Heat Pump Unit
American Standard heat pump troubleshooting
If the compressor is not frozen, then it is most likely one of the starting capacitors on either the compressor or the fan motor. These can fail without warning and without any outward indication. They are shaped like small cans or oblong cans and have 2 or more wires that attach to them with terminals. If you are going to remove one or check them, Make sure the power is off first.
Aug 11, 2014 | American Standard 282999 4" Heat Pump Snow...
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on...
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Nov 26, 2013 | American Standard Heating & Cooling
Aux heat comes on
If you turn your heat on and the temperature is set 3 degrees above what the actual temperature of the room, the auxillary heat will automatically come on. The auxillary heat is an electric heat strip that provides heat to your home while the heat pump is in defrost cycle or if there are extremely low temperatures outside. Try not to set the temperature more than 2 degrees above the actual temperature of the room. Hope this helps.
Jan 25, 2013 | Honeywell Programmable Thermostat Heater
Heat Pump
That is normal. Secondary heat is not needed unless it is very cold outside. If the heat pump can't keep the house warm enough and the temps start to drop, the secondary heat kicks in. 2 degrees is normal.
Aug 18, 2012 | American Standard 5000 Heat Pump Unit
I have a small house with a outside package unit American standard (Trane) Model# WCM030F100BB, italso says BAYHTRN110A. When I select cold from the off position on the thermostat it immediately pops the...
I would check the outdoor unit, Trane uses "Sump Heaters" on their compressors
and when one fails it will blow fuses at the disconnect or trip breakers.
The sump heater is a small metal pencil sized item at the bottom of the compressor
with something that looks like lamp cord going to it. Also when the start capacitor
fails it will exhibit this symptom. Look at the can shaped items inside the cover
If they are leaking, or bulged this may also be the problem.
(with the breakers off to everything including the inside unit to prevent shorting
the transformer)
These are the most common problems and the parts are less than 20 dollars each.
I service 155 trane units at my properties.
hope this helps.
Mar 19, 2011 | American Standard Heating & Cooling
At what temperture should you turn it to aux heat and why does my furnace run for hours
It should switch to the aux heat automatically, when it reaches a preset temperature. Usually, when the outside temperature reaches 32 degrees, if it's a heat pump furnace. It can bet preset a little higher though, depending on the unit. If it's extremely cold outside (in the low teens) It may run a lot longer just to keep up. Especially, if you home is not energy efficient.
If your's is not switching over automatically, the sensor switch on the heat pump may have gone pad or the aux heating strips my not be working at all. This requires the service of qualified heat pump service person..
Feb 11, 2011 | Heating & Cooling
After RTH6400 installation heat strip is no longer actuated look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
