Question about Toys
I need instructions to change the size of the opening that dispenses candy in the motion activated candy dispenser by The Black Series by Shift3
Made by The Black Series by Shift3 a subsidiary of Merchsource, LLC It supposedly has three sizes of holes to dispense more or less candy at a time, I need to know how to change the hole size. No instructions on any kind came with this item.
SOURCE: shampooer dispensing
I occasionally run some water and vinegar (equal parts) through the machine, just as I do for clogged holes in my steam iron. So far it has been doing the job.
Posted on Aug 31, 2008
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
  • 2976 Answers
SOURCE: The hose dispensing hot water to the outlet
You can get good tubing at Home Depot or Lowes. Get the reinforced clear poly tubing, it will hold up better. It has webbing built in to it. You can also go for the stainless steel braided type, if they have it large enough.
Posted on Oct 12, 2009
SOURCE: Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Posted on Jun 23, 2010
vincob
  • 718 Answers
SOURCE: Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Posted on Jul 26, 2010
Testimonial: "Thank you. We thought clogging might be the problem and thick soap makes sense."
The dispenser light won't turn off and ice and water not working after filter change..
I'm not really sure of this one but here's a couple ideas. If the refrigerator ice and water dispenser is not working the dispenser control board might be defective. The control board governs most of the functions of the dispenser system. If only one item of the dispenser system is not working, troubleshoot further to see if the problem is with one of the components in the system. The board is more likely to be the cause of the problem when the entire dispensing system fails. It may also be the door switch If the refrigerator ice and water dispenser is not working. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.Before either of these try shutting it off (or place it in demo mode) and return is to active state.It may just need a reset
Mar 30, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Sensor doesn't work
Unfortunately, there is nothing you can do to fix this on your own. The best solution is to contact the manufacturer. Even if the item is not under warranty, if they have good customer service, they should replace it for you free of charge.
Jan 31, 2013 | Brookstone SnackMan Motion-Activated Treat...
Motion activated candy dispenser will not work
The motion sensor is a glass eye, make sure the eye is clean, if cleaning does not fix the problem then the motion sensor may need replacing.
Jan 21, 2013 | Emerson Refrigerators
How do I open the KC Professional Series OnePak 800 ml skin care dispenser?
Information on your dispenser can be found here:
http://www.kimberly-clark.com/search.aspx?txtSearch=in+sight
Loading Instructions:
http://www.na.kccustomerportal.com/Documents/Upload/Application/2811/Learning%20Center/Product%20Specification/91182-loading_instr.pdf
The dispenser opens from the front and requires 8" clearance.
Open dispenser by inserting index finger or thumb behind the push handle and pushing up on release
latch.
While pushing release latch, grasp dispenser cover with other hand and pull downward.
See the above instructions for illustrations of the opening process.
May 21, 2011 | Kimberly Clark 91180: In Sight Soap Series...
Detergent dispenser fills with water
the black pipe behind it is blocked turn of power take off lid and youll see a soft pipe going to the tub give a few squuezes and it should clear
May 17, 2010 | Washing Machines
My candy cna 145 will not let water into drum. all just floods out of soap dispenser
It sounds as though there is a soap powder blockage in the dispenser or the dispenser hose in to the drum.
Try pushing into the hose with something to clear the blockage.
Please rate my solution.
Jan 23, 2010 | Candy Washing Machines
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Candy
is the tablet released from the dispenser? if not the solenoid in the unit has gone and the dispenser unit will need replacing.
Jun 06, 2007 | Candy 24 in. CD950 Free-standing...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
