Question about Pool & Spa
Need wiring diagram and info for a doerr 1/3hp 115v
Doerr electric motor wiring diagram for model # 62-413 1/3 hp 115v
5 Suggested Answers
john224
  • 1378 Answers
SOURCE: my motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Posted on Jun 15, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
thepool
  • 78 Answers
SOURCE: need wiring diagram for a marathon electric motor
Wiring diagrams for AO Smith motors are located on the side of the motor.
Posted on Apr 21, 2010
  • 8404 Answers
SOURCE: a o smith b854 motor schematic diagram 115v
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Posted on Jul 24, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How do I get a wiring diagram for motor model 370200
There should be a wiring diagram under the connection cover plate that tells how to connect wires for both 115v and 230v service.
By the way, any motor of any brand with a #56 frame and 1 hp or better that runs at 3450-3600 rpm should be suitable for use on a table saw. 1.5 hp would be better. (I upgraded mine to 2hp)
Harbor freight has a suitable 1.5hp replacement motor for $140.
Depending on the motor you get, you may have to buy a pulley at the same time to match the shaft diameter and blade rpms.
Sep 25, 2014 | Saws
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Wiring diagram 3/4 hp boat lift motor
It will be dependent upon the line voltage and switching mechanism...
Please advise drum switch or relays?
115V or 230V
Remote control present?
If a drum switch, is it a 6 or 12 terminal model or some other configuration?
Make and model of the switch?
There may be more questions depending on the answers to these...do you have a wiring diagram for the control? Are you replacing a motor and have the old and new motor schematics?
John
Apr 10, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
I need to convert my 220 wiring back to 110 on my sears air compressor model number 106.173841 with doerr electric motor model 600678.
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
Jan 17, 2010 | Air Tools & Compressors
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
My motor is wired for 230v and I need it to be 115v
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Pool & Spa Logo
70 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
