Question about Yamaha HTR-5440 Receiver
How to reset a yamaha 5440 reciever back to factory settings
Center channel is not working
    Genius:
  • Yamaha Master
  • 1,054 Answers
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Posted on Dec 31, 2012
techman
  • 3130 Answers
SOURCE: Yamaha Receiver Rear-channel Problem
Have you ever used the headphones as the sensor switch could be dirty?? Or if not mybe got a glitch in the micro from a surge or something like that. Try unplugging for a good few hours and restarting again???. Good luck Let us know as the more info we get the better we can assist you.
Posted on May 15, 2006
xscrewdriver
  • 246 Answers
SOURCE: factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
Posted on May 13, 2009
heavyice
  • 374 Answers
SOURCE: Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Posted on Jun 02, 2009
  • 10 Answers
SOURCE: how do i reset a Yamaha RX-V465 back
sledge hammer
Posted on Apr 06, 2010
SOURCE: HI I have a Yamaha
In order to restore the unit to factory settings:
  • Please put the unit into standby mode.
  • Then hold the power button while holding the "straight" button on the front panel of the unit.
  • After approximately 3 seconds "Advanced Setup" should be displayed on the front panel of the unit.
  • From this menu select "init" and then all.
This will restore all factory settings.
For a digital copy of the owner's manual please reply in this thread.
Posted on Feb 28, 2011
How to Set Up the Kbox Pro Digy (FTA Receiver)?
-Extract files (factory bin & version bin)
http://www.abadss.com/forum/983-kbox...te-v2-0-a.html
-from remote, menu-config-system recovery & select delete all channels then factory reset
-insert USB into port in front of reciever, menu-utilities-data transfer-data download (from USB storage)-factory bin (version 1.81)
-menu-config,system recover y and select factory reset
-menu-utilities. data transfer, data download from usb storage-select latest bin (version 2.18)
-menu-config-system recovery-factory reset
-plug khub into reciever using black serial cable, also plug into network cable running to your router or switch
-from controller-menu-utilities-data transfer-data download from USB storage, then select khub activation
-menu-installation-options and make sure all AU options are set off and mode is set to network
-menu-installation-dish settings & config satellites you have setup dishes, then press red button on each satellite to scan in channels
-menu-config-network and change mode to DHCP press green button on remote and wait for it to be complete
-once previous step is complete, turn reciever off with remote, then from back. Wait 30 seconds, turn unit back on
Oct 20, 2016 | Video Game Consoles & Games
No sound from center channel yamaha 5440
mostly such behaviors are caused after the preamp of is faulty or the output section might have developed a problem after ...maybe the cable shorted or the amp fell and the board is broken. need a technician to confirm.
Jun 21, 2014 | Yamaha HTR-5440 Receiver
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I have a yamaha RX-V461B AV receiver. I cannot get the the right front speaker channel to work. All the surround and center speakers work. Even when I run the speaker test, no static comes out from that...
There is no setting that would choose one front speaker to work differently than the other. The amp or something in the audio path within the receiver is failing.
Aug 25, 2011 | Yamaha HTR-6030 Receiver
CD stuck in 5440 deck and won't eject
you'll have to remove the unit and take the cover off to remove disc manually Check that it works normally before refitting unit back in dash
Jan 27, 2010 | Eclipse 5440
Jun 02, 2009 | Yamaha HTR-5440 Receiver
NO LEFT, RIGHT, AND CENTER SURROUND
hi there
have u tried connecting the centre speaker to another amplifier to see if the speaker actually works....
if it does then it cud be the output transistors blown or the actual OP-Amp for that channel
Feb 23, 2009 | Harman Kardon AVR 130 Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Remote will not work on my reciever
I am wondering if it a preprogrammed remote controller or not. If not, you have to reprogram it.
Jul 03, 2007 | Yamaha HTR-5440 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Yamaha HTR-5440 Receiver Logo
217 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
