Question about GE Advantium SCA2001BSS Microwave Oven
Advantium SCA2001BSS03 - I get a F1 alert and advantium stops running before set time is up.
Ge advantium microwave oven model sca2001bss03 runs but will not heat items
  • Open internal fuse
  • Magnetron failure
  • Door interlock failure
  • Control board failure
Apr 29, 2018 | GE Microwave Ovens
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
GE advantium SCA2001BSS03 need owners manual
Yes, here.
Jan 15, 2013 | Microwave Ovens
Advantium microwave won't stop.
If it runs when the door is open it's a bad interlock assembly
Aug 31, 2009 | GE Advantium SCA2000B Microwave Oven
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
Trouble code F1
F1 This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced.
Good Luck
Please rate FixYa!
Dec 18, 2008 | GE Advantium 120 Convection/Microwave Oven
Sca2000fww 02 trouble code F1
Good Luck
Please rate FixYa!
Sca2001bss03-Advantium oven-built 06/2000
If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts (such as "button") by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you find you need control panel repair, we do that nationwide for $39.95 in most cases. See: http://tinyurl.com/yzjozk
Mar 19, 2007 | GE Advantium 120 Convection/Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
43 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
