Amazon Kindle Fire HD Logo
kevin joy Posted on Dec 30, 2012
The screen does not load it stayes blue
It was working fine about an hour ago. it was plugged in to charge, and when it was unplugged i tried to turn it on and the screen satys blue it does not load.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
405
Points
16
You need to reset it. there are different fires so not sure where the place is, but ours is on the back. use a paper clip, stick in the hole and it will reset and come on. you should refer to your users manual on line. probably under amazon.com kindle help.
Kindle battery won't charge . Kindle doesn't stay open
Hello
If the battery isn't too far gone, here's how to revive it:
    1.Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours.
    2.If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds.
    For any help or support just visit us: Kindle Fire Support
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
My Kindle will not charge - I have trued with various chargers I own
Hello
Just follow these steps to fix this issue:
1. Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored kindle. If not, go on to step 2.
2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds.
3. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds.
4. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again.
5. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen.
For any help or query visit us: www Kindle Com Support
99% charged. If plugged in it stays on. If unplugged it turns on for one second and turns off. Tried resetting it with paper clip as the manual states. Help
Hi ...just because a battery charges to 99 percent does not mean that it retains the charge as it did when new. Almost certainly need new batteies....nothing more
2answers
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
2answers
Battery light stays on even after comp is turned off or the battery charger is unplugged
hi, sounds like you need to replace your hard drive, blue screen of death means 2 things bad memory or hard drive regards
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
