Question about Ricoh Aficio Mp 2000l Copier / Printer / Scanner
Ricoh Aficio MP 2000Le Machine error code SC 546 appears.
I have a machine RICOH Aficio MP 2000 Le and errorcode SC546 appers.
  • Anonymous Mar 20, 2014
    when i switch the machine on, the expusor lamp start runining after setup it comes the sc 101
    once i switch the machine on after setup sc 101 apear in the lcd. what is wrong
    New Friend:
"Unstable Fusing Temperature" Chang Fusing Thermistor.
Posted on Jan 07, 2013
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
If u ave check your conections wel and code stil thr change the thermistor and the power sopply unit.
Posted on May 26, 2016
SOURCE:
Bubbabear64
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Ickoajnc
  • 211 Answers
SOURCE: error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Posted on Jul 11, 2009
  • 19 Answers
SOURCE: i have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Posted on Dec 24, 2008
  • 11 Answers
SOURCE: I have a ricoh aficio 2035 that reads error sc 546
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Posted on Aug 17, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
Posted on Oct 20, 2009
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Where i can get ricoh aficio mp 1600 le driver for window 7
Hello!
You can open www.ricoh-support.com and download the driver for free.
You will see this web page. Just choose the model and than choose the OS.
Sep 20, 2011 | Ricoh Aficio MP 1600L Black and White...
Cannot find linux driver for Ricoh Aficio MP 2000 Le (the home page of the printer shows Aficio MP 1600L) printer.
have you tryed to down load the drivers anyway some times a company will put out a new printer but the drivers are the same.
May 14, 2011 | Computers & Internet
Lost driver of aficio mp 1600 le
Please follow this link for download driver of aficio mp 1600 le
http://en.kioskea.net/download/download-938-driver-ricoh-aficio-gx3000
thanking you
davevipul197
Dec 20, 2010 | Computers & Internet
I would like to install ricoh aficio MP 2000 Le printer driver form the net.
how to install ricoh mp 2000le printer driver for windows 7
Jun 19, 2010 | Computers & Internet
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
The RICOH Aficio 2000 MP 2000 Le is connected to MAC O/S and doesn't print. Pl. help
what version is your mac O/S ? if it is the new 10.6 snow leopard you need to download the driver from mac site and install it, not all are out for that version. As a work around you may be able to use an HP laserjet 5 driver.
Mar 09, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio Mp 2000l Copier / Printer / Scanner Logo
1,239 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
