Question about Electrical Supplies
Low voltage coming from outlet
GFCI tripped in kitchen and now the hot wire is only showing between 2.8v and 4.5v
  • 5,089 Answers
1) Copy following links:
http://waterheatertimer.org/Troubleshoot-household-electricity.html
http://waterheatertimer.org/pdf/How-to-find-ground-fault-in-household-electric-circuit.pdf
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
2) Move hot wire to different, same-amp, circuit breaker and see if problem persists.
Look for loose quick connect on back of each switch and outlet on circuit, including GFCI, replace GFCI.
3) Add comment and say what you find.
Posted on Dec 31, 2012
Testimonial: "This was great advice, and sniffed right the correct path. It turned out to be a tripped breaker in the sub panel, which feeds the breaker box (or whatever you want to call it) power. Thank you for the quick response; this was confusing one. -jason"
4 Suggested Answers
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
rcalorisian
  • 313 Answers
SOURCE: I'm installing a 40A 2-pole
Try this...
You mentioned a 8-3 cable suppling power to the sub-panel. I am assuming you have a 8-3 WITH ground or 4 conductors, black, red, white AND ground.
In the sub-panel do not bond the neutral bar to the box or ground bar. If there is a green bonding screw on the neutral bar...remove it. If you have only one (1) neutral bar add another bar for your grounds and bond this bar to the box. Keep the neutrals isolated from the grounds.
I hope this has helped. If you need additional information please send me a follow-question.
Posted on Sep 10, 2009
john224
  • 1378 Answers
SOURCE: 20 A AFCI Homeline trips
You should not have multiple GFCI devices in any one circuit. Change out the outlet and label it
GFCI Protected if necessary...Your problem of nuisance trips should go away.
John
Posted on Sep 21, 2011
I have a coleman gen. 6500 voltage at meter but not at the outlet
First check to see if your gen has a tripped GFCI that needs to be reset at the outlet. If it's not a GFCI outlet, it's possible you may have a disconnected or broken wire going to the outlet. You'll need to trace the wiring back to the meter..
Feb 27, 2017 | Coleman Electrical Supplies
No power to two kitchen outlets. Reset breaker.
GFCI? Reset outlets. There are usually gfci outlets in kitchens.
Jan 30, 2015 | Electrical Supplies
Outdoor electric recepticle GFI tripped (I'm guessing during recent rain) and will not reset. Would this indicate faulty GFI or something wrong in system. This was installed about 2 yrs. ago and has been...
if the outlet was wired right and working fine before -- then ' yes ' the GFI has tripped and it could have failed do to the rain. replace the outlet with a new GFI outlet and I would also suggest that since you have the outlet outside that you install it into a outdoor weather proof outlet box.
c...
Jan 18, 2011 | Lutron SCR-15-GFCI-SW Satin Colors 15A...
What is wrong when you install a GFI outlet and the green light in the corner goes on than goes right back off than when you try and plug something in the outlet it doesn't have power?
It means that the outlet has tripped. There are one of three problems which you can check. 1. The outlet was wired wrong. On many new GFCI receptacles if the wiring is incorrect the receptacle will trip and not allow you to use it. Proper wiring methods can be found by searching in your search bar "how to wire a gfci". It is possible that what was plugged in went over the amp rating of the GFCI. causing it to trip (note: not as likely as your main circuit breaker would have tripped first). The only other things, which has happened to me a lot is the outlet can be super sensitive to current change. GFCI measure high and quick rises in current. If it is too sensitive to the rise in current the receptacle will trip. In this case it will need replacement, and the store will exchange it for you free of charge.
Jun 11, 2010 | IDEAL 61-534 Digital Breaker Finder W/GFCI
I''ve gotta small issue with an electrical outlet in my kitchen. I've got a GFI that is connected with two additional outlets as would be the norm. I was having a problem with the GFI popping every once in...
GFCI receptacles are polarized and connecting them correctly is critical. The hot wire should be black, blue, red, etc. The neutral should be white or natural gray. The ground should be green (if equipped).
Also, it's common to have other receptacles in a kitchen wired "downstream" of a GFCI so that if the GFCI trips or there is an issue with another non GFCI outlet, you're still protected.
Check all outlets in the kitchen and be sure they are wired correctly and in good shape. Unplug everything while you test. If the GFCI still trips, start looking for loose neutrals or bad ground wiring (or no ground) at the other receptacles since you said you already checked the breaker box.
A coffee maker can be a cuplrit that causes a GFCI to trip since it is a heating device and uses water, which can make them more susceptible to electrical problems. Check the microwave too (if equipped).
Jan 02, 2010 | IDEAL MCM TESTER GFI CIRCUIT
The GFCI outlet is tripping while trying to start
The fuse is in the harness and will be a fatter portion of wire. It is not recommended to use a GFCI protected circuit for the spark type ignition ranges. If it did or does work consider yourself fortunate.
Eric
Sep 28, 2009 | Hotpoint RGB528 Gas Kitchen Range
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Voltmeter trips GFCI
I think this is normal for a GFCI.
May 01, 2009 | IDEAL 61-086 Vol-Con XL Solenoid Voltage...
Gfci breaker for spa
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Gfci trips.it protects 4 receptacles downstram from it.If I disconnect from downstream receptacles it will not trip.This is on kitchen counter-top circuit.All wiring and devices are only 6 months...
There can be a few different reason for a trip. 1. Amps exceed rating off GFCI ie 15 amp receptacle can only handle up to 15 amp anymore and it will trip. 2. miss wiring; neutral must be on white screws hot on black and ground, green also inlet power (line) must be on bottom screws, outlet or load must be on top 3, a short, whether it be neutral or hot touching something in the box. Frayed wire, wire next to side of interior of box or yes moisture. Also a short in an appliance aven a new one can cause a trip. Remember if the refrigerator is on this same circuit, which is not a good idea it can cause a trip. At start up the fridge can spike to near 15 amps and a voltage spike can cause a gfci to trip. There are 20amp GFCI's so that can be your last resort, if all else fails.
Jan 17, 2009 | Sharp 13K-M100 13" TV
Electrical Supplies Logo
146 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
