Question about Tools & Hardware - Others
Hoover electrical polisher/scruber model 0212
How to remove brushes?
2 Suggested Answers
SOURCE: I have an old Regina 12" twin brush floor
Mine just snap in. To remove, I just pull them out.
Posted on Sep 20, 2010
Hoover steam vac, center brush falls out repeatedly
Hey there! All the brushes have to work together to function properly. If the center brush is falling out the brush block assembly is broken and will need to be replaced. Follow the link below to place an order for a replacement brush block.
Search Results
Hope this was helpful!
Aug 02, 2014 | Hoover C3820 Commercial Steam Vac Black...
Wiring diagram electric hob
www.electroluxappliances.com/Owner-Support
Aug 14, 2013 | Electrolux E604-220V50HZ Model E604 Floor...
Hoover rug scruber hose broke from clean water to brushes it has an inter hose running through it
Is this the 1 1/2" clear hose that is on the right side that you can see when the handle is released? It stretches for the base of the machine to the upper handle? If it is, the hose must be replaced. The ends on the hose are permanently attached during manufacturing.
Nov 16, 2011 | Vacuums
Our Hoover U8172-900 brush motor is not working. Do you have a wiring diagram so I can determine if the motor circuit board is the problem or the motor?
No diagrram is necessary unless you have dismandled.
Check if the brushes are touching the mtor commutator. If not you can easily remove both the brushes and polish the surface evenly .Insert only after cleaning the motor commutator till the copper shines.
Use can check for the continuity of the brushes to show that the armature is working Ok.
Now check the filed winding. Both the windiings must snot show any leak or short to the body. If so the motor is fault.
If field is ok with the resistance check then check for power supply to mtor when switch is triggered . If not check cord and switch.
Hope this tip helps.
Aug 29, 2010 | Hoover Vacuums
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
I have a hoover elite 200 it did not have a belt on it when i got it and i cant find the drive shaft.
You must remove the lid of the vac and find the pulley end of the brush. directly behind it one hand length you will see a small silver shaft. If the shaft is other than silver it is coated with burned rubber. or rust and dirt.
Clean off the burned rubber polishing the shaft with wet dry sandpaper . Then rotate by hand to test for any blockage in the motor fan. Also rotate the brush roll to see that it spins freely. Using a genuine hoover ELITE belt wrap the belt around the motor shaft and brush roll and use the brush to stretch the belt forward as you lower the brush into place. Once seated , rotate the brush again to see that the belt is turning, then reinstall the lid. Do not pick up anything larger than your fingernail or you will blow the fan on this unit.
Sep 12, 2009 | Vacuums
My dewalt polisher will doesnt turn on when connected to outlet?
I would check the brushes. These are small carbon blocks that transfer the electricity to the armature and are usually easily accessible from outside the tool. Look for two round disk like caps with a screw slot. Undo the caps and take out the brush and you may find it is worn to the limit.
Sep 03, 2009 | Dewalt Dw849 Electric Auto...
I am looking for a switch for a Hoover floor polisher model 0211. Thsi model is about 50 years old.
Generic problem for all Vacuums
I am looking for a
posted by csoper on Apr 18, 2008
Report abuse
I am looking for a switch for a Hoover floor polisher model 0211. This model is about 50 years old.
Hoover Floor Polisher #0211
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try your local vacuum dealer in your area in the yellow pages or you can try the Hoover fact serv but there is one other place the has been open since 1949 that may have the switch for you, either new or used. The companies and factory listings are listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 this is the company that has been in business since 1949.
Apr 18, 2008 | Vacuums
Tools & Hardware - Others Logo
155 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
