Question about Whirlpool Dishwashers
We have whirlpool dishwasher mod du1055xtvb5 ser f107007973 type 575-0 when we go to start it . we can not get it to start up we have tryed to reset the controls but it won't start the cycle
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Whirlpool dishwasher Model DU1345XTVQO, Serial
Hello, Welcome to FixYa.
Based on your post I understand you have a drainage problem with a Whirlpool dishwasher. t
ypically with these machines having poor washing and incomplete draining it can be chalked up to obstructions in the sump assembly. Here's how to inspect it and clean it if necessary.
Try this link if you think you're not too confident. They aren't pros, but it is a good guide for accessing the sump assembly relatively easy. This combined with my tutorial you should be fine.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
NOTE: Pay particular attention to the area where I've placed the arrow. It is a back flow check valve and can get debris stuck in it allowing water to back flow into the sump after the drain cycle ends, hence you get water left behind.
The other thing to inspect is the drain. The proper drain should actually be tied up at least as hi as the top of the dishwasher and the closer to the machine the better, but if it drains into a sink or disposer right next to the machine as long as it is tied up under the sink it should be fine...you also want to rule out any kinks in the hose of course.
Now you'll need to run a "reset" test sequence to observe it's performance. Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the pump itself is at fault...we'll cross that bridge if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 24, 2011
puertobori
  • 7733 Answers
SOURCE: have a 7 blink error code coming out of a
Go here ->LINK
Posted on Oct 05, 2011
User manual for Kenmore dish washer Mod#665.13842K601 Type 575-0
You can download th manual for free at the following Kenmore Support link
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0608085.pdf
Sep 09, 2012 | Kenmore Dishwashers
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Whirlpool Type 575-0 Dishwasher has a film on the glass ware
try only filling the detergent cup halfway. but before doing that run a cup of vinegar through the dishwasher. that should solve the problem. you are using to much detergent. plus use powder detergent if it is stated in your owners manuel.
Nov 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
