Question about Panasonic KX-FB421 Plain Paper Film Fax
Fax machine I have a panasonic fax machine and the paper seems to get stuck going thur when I am faxing.. I am looking for a solution in how to clean the fax machine or is there something else that can be done to solve this problem. It will not feed more then 1 sheet ata time and when u try to feel the next sheet it stops. I hope this is enough info and I can solve this problems asap. Thank you Linda
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
Most likely you will need parts. When fax machines do this, the paper separation pad is worn out or wearing down. If you get parts, you'll need both the pad and feed roller that ride on the pad.
Posted on Jun 25, 2007
Panasonic how to clean rubber rollers
What I have done in the past is take a piece of 8 1/2 x 11 paper card stock of thicker than 20 lb. Put alcohol on bottom part of paper and start feeding it in BUT HOLD ON TO IT DO NOT LET IT FEED THRU. The friction will clean rollers. You'll get a paper jam of course. Reset and do it again. Has always worked for me.
Oct 11, 2014 | Panasonic Office Equipment & Supplies
Clean Fax KXFHD351 Panasonic
Nope No mirror, try cleaning the drum corona wire. Gently clean wire with a #2 pecil eraser to remove any dirt, then open fax sheet feeder and GENTLY clean with alcohol wipe across the light bar scanner. Paper dust builds up on this.
Jul 08, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper is not "picked up" to print.
TRY CLEANING THE PAPER ROLLER WITH DENATUYRED ALCAHOL OR MAY BE THERE IS SOME THING STUCK IN THE MACHINE GO AHEAD AND LOOK GOOD LUCK BROTHER TECH
Jan 28, 2009 | Brother IntelliFAX 2800 Laser Fax
"Check Document" message
look for a switch trapped down in the document feeder
Jan 28, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic Fax Phone Can't send or Receive fax
there maybe a small paper jam in the machine that you are missing. if you are handy, unplug the fax machine and look around where the paper is fed into. if you see paper trapped anywhere, try pulling it out with a pair of needle nose pliers. the machine will not work right till the jam is cleared.
hope this helps.
wg
Feb 10, 2008 | Office Equipment & Supplies
Failed Pick Up
use alcohol and dry cloth and clean all what lubricated,fax machines don`t lubricate!!!!!!!.after cleaning the fax will work properly
Oct 29, 2007 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX_FL 520 Fax problem
THE DOCUMENT SENSOR OR THE DOCUMENT END SENSOR ARE EITHER BAD OR THE SENSOR LEVER IS STUCK OR BROKEN CHECK THESE AND YR PROBLEM WILL BE RESOLVED HAPPY FAXING OMNIPRESENT
Sep 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Sending faxes
SEEMS THE RECEIVING FAX IS SET ON AN EXTENSION , SO U WILL HAVE TO FOLLOW THE PROCESS. HAPPY FAXING OMNIPRESENT
Sep 05, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Panasonic KX-FB421 Plain Paper Film Fax Logo
75 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
