SOURCE: restore window vista for acer aspire 5920
Hi Acer supply the restoration files in a hidden partition on your hard drive. If it is the same as mine try this. Start the pc, then while the Acer logo is showing, press ALT & F10 at the same time. Then just follow the instructions. Bear in mind that this will format your C drive so you should do a backup of any important data first. Hope this helps.
SOURCE: acer 3680 factory reset
here is the link to the manual for your laptop. please go there and take note of pages 70-73 that show how to restore your system with and without the disks.
SOURCE: acer m5100 recovery discs
Restore disks are available from Acer. If you complain loud enough they may even send them for free.
SOURCE: how to restore acer extensa5220 notebook back to its original set
From Acer direct
The
other way before Vista starts up is to tap ALT + F10 (at the same time
repeatedly) when the computer is first switched on.. The window of
opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then
it indicates that you have tapped the ALT + F10 correctly, and all you
now need to do is press “Enter” and the Recovery program should load on
your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
