Question about Worldtech Devices World Tech 85618 2CH Silverlit Gyrotor X-Rotor RC Helicopter
Ir helicopter only upper wing spinning
I have a world tech toys 2 channel infrared helicopter. It was working great but suddenly the lower wing has stopped spinning. Upper wing is spinning fine. The heli is not flying snymore. Can anyone help on how to fix it?
  • heatpak Feb 10, 2013
    I curious too. New out of box with no tail rotor spin.
    New Friend:
Just had the same problem. The motors for for the lower rotor and tail need to be replaced. If it's anything like mine, you can use parts for Syma 107. Probably about $4 each on ebay. I took a broken motor apart. The brush contacts are very fragile and cannot last very long.
Posted on Feb 07, 2013
    New Friend:
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Posted on Feb 05, 2013
Why won't world tech toys phantom 3.5 ir helicopter charge?
check charger if faulty,,then check charging connecting jack in helicopter
May 14, 2014 | SYMA Toys industrial New Syma S107 Radio...
The lower blades of my ev.01 helicopter are not working, how do i fix this?
Sophie, you will find that the very tiny gear at the bottom of the rearmost motor has either chewed up or come adrift. I have the same fault exactly and am trying to locate a new gear. If anyone can help locate one the please email j r siddle at hot mail dot co uk (I am sure you can work out the addy)
Dec 29, 2012 | Toys
Bought Nano Hercules RC Helicopter. Flew it once and now lower rotor won't turn. Tried to call World Tech
I, too, have the Nano RC heli. Mine spins and spins faster if I try and take off.
Yours is a relatively easy fix. There are SCREWS under the rotor blades on the bottom. Tighten those.
Dec 28, 2012 | Toys
World Tech Saturn-X - spins, rudder trim doesn't help
I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at thedew312@gmail.com if you need more help finding where the wires connect
Dec 28, 2012 | Worldtech Devices World Tech 85618 2CH...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
Find charger for world tech rc helicopter skyhawk
good day,
hope this link below will help tp solve your problem.
toys
Apr 30, 2010 | Worldtech Devices World Tech 14422 multi 4...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Worldtech Devices World Tech 85618 2CH Silverlit Gyrotor X-Rotor RC Helicopter Logo
636 people viewed this question
Top Worldtech Devices Toys Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Worldtech Devices Toy Expert? Answer questions, earn points and help others
