Question about Sony KP-53V80 53" Rear Projection Television
Sony KP-53V80 is not turning on.
No picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
  • 916 Answers
4 LED flashes indicated a faulty IC board
Posted on Jan 18, 2009
    President:
  • 373 Answers
A 6 flash shutdown can indicate power supply problems or an open thermal fuse. To be sure, you should have a technician verify your problem.
  • 716 Answers
Heres A Manual On Sony Blinking Codes Check It Out Its Very Helpful. Click Here
You Can Call Sony For Parts
1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 8:00AM-12:00AM
Sat-Sun 9:00AM-8:00PM EST
    Scholar:
  • 160 Answers
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
    Sergeant:
  • 221 Answers
Its the problem of main board circuit in the tv.it has to be checked by meter.
2 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: I have a Sony Projection
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
My 12 year old Sony KP-53V80 TV suddenly turned off and will not show a picture just a small rainbow at the top of the screen, then a whistling sound, crack and turns back off. can you help?
sounds like the inverter went bad...There's a high voltage device in there that runs the whole "picture" thing. There are capacitors involved with it that have probably failed leading to this mess.. That would be what that "crack" is...If you try to turn it back on does it just "click " and then stay off?
Jun 09, 2012 | Sony KP-53V80 53" Rear Projection...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
Check IC1509, Q1505
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony KP-53xbr45 problem
on your model which is a RA-1 chassis the power light blinking steady just means the standby voltages are operating, so you will need to trouble shoot the power supply. you will either need the service manual or training manual to trck down the faulty component.
Jun 22, 2008 | Sony KP-53XBR45 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57HW40
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
389 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
