Wireless adapter on toshiba laptop just stops working
At times the adapter "shows" everything is going including the adapter showing that it's working okay. But at this time, it doesn't see any wireless networks at all. I'm not sure what else to look at - any thoughts?
Make sure you didnt accidently put it in the recycling bin pull up bin and see what you have thrown out
Posted on Dec 30, 2012
  • 7,627 Answers
On some laptops you can access the wireless adapter quite easily. perhaps it's only a bad connection, requiring some Electronic Contact Cleaner, or loose connection. Or the antenna, usually located behind the monitor, has a pinched , broken wire. The wire feeds through the hinges. Or , as you most likely suspect, the wireless adapter may be bad. I don't know the model of Toshiba. Take a look at this: http://www.youtube.com/watch?v=z19kc5fERsE
SOURCE: wireless adapter not showing up in network conections,icon
This happened to me when I had to install a wireless router in my house using my laptop to initialize the network for the first time.
The start up software messed with my settings for wireless detection on my laptop. It turned off the automatic detect for wireless networks in the
"Wireless Zero Configuration"
(This has the settings for the 802.11 wireless adapters
i.e. the one that comes with the R4000 presario)
to get to this hit start>run...
and type in this:
%SystemRoot%\system32\services.msc /s
go to "Wireless Zero Configuration" and enable automatic startup
, if the service is stopped, start it.
hit the apply button to save your settings.
Posted on May 21, 2008
SOURCE: Wireless network adapter - Vista
I know this is over a year, but have you tried checking the bios setting? It may be that the bios has an option to disable the integrated wlan.
Posted on Nov 29, 2008
contest25
  • 115 Answers
SOURCE: Toshiba Satellite A200 Wireless Adapter Not Functional
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
Posted on Feb 25, 2009
the_fire
  • 432 Answers
SOURCE: Wireless adapter not visible
Is it not physically connected or is there an on off slider switch thats turned off ?
Still does not explain why its not showing up in device manager.
Posted on Apr 15, 2009
shahabdun
  • 249 Answers
SOURCE: The Fast Ethernet Adapter of my Laptop doesn't
check the status of the adapter in Device manager under network connections.It should be enabled.
Posted on Jul 06, 2009
Hardware Conflict problem in xp
good luck Microsoft has stopped any support for XP (the best operating system they ever had or will have since it was based on NT) Go to search put in Prefetch and open that folder delete ALL of the files in that folder it will free up a lot of space for you to work with. I have a shortcut on my desk top for prefetch to save time Pokey Delaroderie
Oct 21, 2012 | Computers & Internet
Hi my wireless has just gone it is not recognized in the device manager and a USB Device not Recognized pop up is showing up. i restart it a couple of times and once it did showed up but after i did it...
Try unplugging the wireless adapter and plugging into a different usb connection. Windows will install it and then check if it works. You can also try uninstalling the adapter from the device manager and search the manufacturers support website for the driver download page. You should be able to find the wireless adapter driver here, download and follow installation instructions to install a new one.
Mar 28, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
I have a Toshiba Satellite A135-S4527 and it will not turn on. I checked the AC adapter and I am getting 19 Volts and my laptop shows that i have power going to the laptop but yet it will not turn on.
Welcome to Fixya.
It seems like you are experiencing a "No power/no post" issue on your laptop, here are my recommendations :
  • Disconnect everything attached to your laptop (USB cables, etc)
  • Disconnect the ac adapter
  • Carefully remove the laptop's battery
  • Press and hold down on the power button for at least 10 seconds
  • Connect the ac adapter to laptop without the battery and turn it on
  • If this works, return the battery to the laptop and try it again with the ac adapter
If none of the above procedure works, then the laptop needs to be serviced. I've included Toshiba's support contacts below for your further reference :
Toshiba Support
Hope this helps and Thanks for using Fixya.
Jan 22, 2011 | Toshiba Satellite A135-S4527 Notebook
Cannot stay connected on wireless networks. Troubleshooter shows problem detected with wireless network adapter and a cable unplugged. I am running a toshiba satellite L505d with a realtek RTL8187SE...
Hi, Please make sure that you have turned on the wireless switch on your laptop because this is a message that usually appears if the wireless on the laptop is disabled.Also please update the wireless drivers for your laptop from the Toshiba website. Thank you for your time and best wishes for your effort.
Jan 08, 2011 | Toshiba (PA3212U) Wireless Adapter
Hi, I have reinstalled my window XP SP3 but after reinstalling window my wireless(Adapter name: dell wirless 1395 WLAN mini-card) is not working properly. I have installed latest driver on my Dell...
Verify that you have the correct type of authentication in wireless- if your router is set to WPA2, then you would have to go under the connection properties > security tab to change it to match that setup. If that does not work, then the issue may be that the wireless card is defective and starting to fail.
Nov 22, 2010 | Dell Inspiron 1525 Notebook
MY LG e500 shows "Wireless
Hi
I would go to device manager go to network devices find the wireless adapter and uninstall it then restart your notebook and hopefully windows will reinstall it correctly then go into the properties and tell it to show in taskbar when available
Nov 15, 2010 | LG X-Note LM50 Notebook
I have a toshiba satellite A355. The wireless just stopped working. the switch won't light and i can't connect to a network. tried to diagnose the problem and ran a testing showing that the "radio" is...
Go to the Toshiba Support Website and Download/Install any/all Software & Hardware Updates related to your Model. Also, just to rule out the possibilities that you may have a Virus, Run a Full System Virus Scan.. I recommend Malwarebytes.
May 13, 2010 | Toshiba Satellite A60 Notebook
A35-S159 TOSHIBA satellite
Toshiba no longer supports the A35-S159 laptop.I found my drivers here free! http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1176.html
Sep 26, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
