Dvd eject slot not working on dell optiplex gx620 desktopcomputer
  • 7,627 Answers
Start Menu, Computer, right click DVD rom, scroll down, click eject. If the DVD in the DVD rom is broken,damaged, remove Drive, disassemble. Try to open the front panel DVD rom door and push the button on the DVD rom drive.
Posted on Dec 30, 2012
bschilz
  • 2049 Answers
SOURCE: i have a dell optiplex gx620 and it wont turn on
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Posted on Oct 20, 2009
yngwei50
  • 134 Answers
SOURCE: Adding network drivers to dell optiplex gx620
Just download the drivers here the link http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Posted on Dec 18, 2009
SOURCE: How to open the case
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtcvrop0.htm#wp1051283
Posted on Mar 08, 2010
  • 113 Answers
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Posted on Jul 14, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
Hello, I have a Dell Optiplex GX620 desktop
I would remove the new card, and recheck vol. Next, change PCI slots. Pick up a cheap audio card and see how works. Good,luck
Oct 19, 2013 | Dell OptiPlex Computers & Internet
My dell GX620 desktop does not power when ever I plug in the network (RJ 45) cable. Also if the system has boots to desktop, and I plug in the network cable it automatically goes off.
1) Does it have a separate Ethernet Card, or is it integrated?
(Part of the motherboard)
Reasoning?
The Dell Optiplex GX620 comes with Integrated networking.
The chipset is a Broadcom 572.
It's part of the motherboard, and you plug the Ethernet Cable into the back of the computer.
However, you could have a separate Ethernet Card, plugged into the white PCI expansion slot on the motherboard.
http://www.ebay.com/itm/Dell-Optiplex-GX620-SFF-Motherboard-F8101-KH290-PY423-20-Available-/370743464509?pt=Motherboards&hash=item565208523d
A) If you are using a separate Ethernet Card, replace it.
B) If you are using the Intergrated networking of the motherboard, (Plug Ethernet cable into back of computer), use an Ethernet Card instead.
White PCI slot.
You have a short circuit when you plug the Ethernet Cable into the motherboard. Don't use the motherboard networking, use an Ethernet Card.
2) Plugging an Ethernet Cable into a computer that is on, = No.
It is not a Plug N' Play item.
(Not stating this is what you are doing.
Just posting in case you are. Burns out the Ethernet chipset on the motherboard)
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Dell OptiPlex GX620 PC Desktop
My dell optiplex gx620 keeps restarting it does not even enter bios plz help
Please see that the connectors on the PC, check if there is loose connect on the board. Also if the bios battery is low on voltage- check with a multimeter.
Finally the memory card can also have a loose connection on the slot, remove and reset or try with another card.
Apr 12, 2011 | Dell OptiPlex GX620 PC Desktop
I'm wanting to upgrade the RAM in my Dell Optiplex GX620. I've had no luck finding what RAM is compatible. Are you able to help?
DDR 2 with 533MHz this is the RAM that comes by default for this model...
you can install RAM in size of 2GB per slot...
Dec 16, 2010 | Dell OptiPlex GX620 PC Desktop
Just looking for the motherboard manual and cd for a dell optiplex gx620. I'm learning about my computer.
You can download the manuals for your OptiPlex GX620 PC directly from the Dell website here:
http://support.dell.com/support/edocs/systems/opgx620/en/index.htm
Oct 17, 2010 | Dell OptiPlex GX620 PC Desktop
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
Hi MY Dell OptiPlex GX620 have a hardware
try the bios settings is your monitor in a grafics card slot
also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Nov 24, 2009 | Dell OptiPlex GX620n PC Desktop
I HAVE A DELL OPTIPLEX GX620 AND WISH TO KNOW HOW TO INSTALL A DVD REWRITER INTO MACHINE DO I JUST TAKE OUT THE DVD ROM AND INSTALL IN SAME PLACE
You can simply replace the old drive with new one. Make sure you have the jumpers on the same place as the previous one...
This is the jumper image for your reference
Sep 25, 2009 | Dell OptiPlex GX620 PC Desktop
Ubs plug in
Looking at the picture of your computer, I dont see any colored usb sockets. If it indeed the usb port you want to use,anyone will do.
Dec 19, 2007 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
