Question about Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my bluetooth settings are enabled. can you please help me?
  • ashawee88200 Jan 18, 2009
    it will connect successfully but then itll disconnect on its own seconds later.
  • bliggie75 Apr 03, 2009
    This same problem is happening to my Blackberry Curve. Removing and re-pairing doesnt seem to be working either..any other suggestions?
    President:
  • 623 Answers
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Posted on Jan 18, 2009
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
H700/ blackberry storm
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 11, 2009 | Motorola Mobility H700 Wireless Headset
After i enter my passkey it says connection failure for my h700 blue tooth
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey is 0000, four zeros.
May 23, 2009 | Motorola Mobility H700 Wireless Headset
Won't stay connected.
check the batteries on the BT headset
May 15, 2009 | Motorola Mobility H700 Wireless Headset
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
I can't sync my motorola h700c with my blackberry
1. Bluetooth enabled?
2. Options -> Bluetooth -> Add Device
Search for Bluetooth devices on the blackberry. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the blackberry and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the blackberry.
Dec 11, 2008 | Motorola Mobility H700 Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
334 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
