Question about Imation Apollo (27119) 500 GB USB Hard Drive
I cant copy files from my computer onto my imation apollo M100 320gb hard drive
bob_computer
  • 3153 Answers
SOURCE: Imation apollo pro ux 500gb external hard drive
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
Biggdex35
  • 333 Answers
SOURCE: My Apollo 250GB USB hard drive can't be detected
It should be in My Computer after you plug it in. If not, then go to control panel and search for new hardware. Click on system in control panel it should be listed under usb. Maybee it needs a new driver.
Posted on May 17, 2010
SOURCE: I got a Imation Apollo ii 320gb portable hard
Try to reload the operating system you are using i.e windows xp,one of the windows files may have been corrupted and how can you load it. if you have a important files on your desktop try to copy it into any storage device such as flash drive or memory card after you have transfer those files to the backup you use as your storage device unplug it from the system then format the system and load it with your windows xp any one that support service pack 2. how can you format and load your system. in the start up of the system press the key your system support to enter setup some system like compaq for you to enter their setup you have to press F10, some system support DEL to enter setup and some system support F1,while some support F2, any one your system support press it when you get to the setup area to advance setup or check those drop list one after the other until you see were you see booting or booting sequence or booting other then set your CD rom to the first boot follow the order the system give to you then save your setting by pressing F10 key or move your cursor to where you see save and exit and press the enter key for the system to restart then insert your operating system software i.e windows xp immediately the system restart and boot it will bring press any key to boot from cd rom then press enter key then follow the instrution.
Posted on Jun 08, 2010
  • 916 Answers
SOURCE: Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Posted on Mar 14, 2011
  • 224 Answers
SOURCE: my "imation apollo 25-PHDD
You need data reovery help. This guy does it remotely and works from donations. FreeDataRecovery.us
Posted on Jul 13, 2011
What does it mean when my saved files on my hard drive are no longer viewable on my Laptop (acer) I'm currently accessing my saved files on my hard drive via the 'recent places' in the 'Favourites' op
try manually looking for the files in the drive or have windows look for them for you long as the windows index system is running you maybe able to find the files your looking for
May 26, 2014 | Imation Apollo UX 2.5" USB Portable (250...
How to use as data backup
Connect the drive to your computer.
Open "My Documents".
Click "Edit".
Click "Select All".
right-mouse-click on one of the highlighted files/folder, and choose "Send To".
Choose the drive-letter for the external drive.
Your files will be copied.
Mar 03, 2014 | Imation Apollo Expert M200 Portable Hard...
How to back up all file from my laptop
No, simply connecting it will NOT trigger a copy operation.
Feb 28, 2014 | Imation 27390 Apollo Expert UX 2.5" 320GB...
IMac won't read Imation 160GB Apollo 2.5
Mac's won't read windows format disc, even if it's capable of reading the files wich I believe Newer Mac Operating Systems CAN DO, it can not read the file SYSTEM used to place them on the disc. You need a third computer. Put the files on a nother computer or two if you need the room or on another media or pocket drive. Use a program that VERIFIES the were moved without errors while copying them, the use the Mac to format the now empty disc drive and download Mac Pooler, or File Stuffer, and copy the files back onto the disc. Now the Mac will be able to read the drive they're on.
Feb 16, 2014 | Imation 160GB Apollo 2.5" Portable USB 2.0...
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
Imation 250 12.5m U3 in my laptop but cant open
Connect it to a different computer.
If no success, it is "dead".
Oct 24, 2013 | Imation Apollo UX 2.5" USB Portable (250...
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem
Please repost your problem, and enter a description of your problem in the textbox where it says "Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem"
Aug 25, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
Aug 15, 2011 | Computers & Internet
Hello there. I can't view the files on my Imation Apollo M100 2.5 Portable HDD. I was able to use a few days back, copied and transferred some files to and from my netbook. But now, I couldn't...
change the usb and then check else if its working or not..check also if its working on any other computer..if its not even detectable at other computer as well then the hdd itself must be the faulty..contact the manufacturer
Aug 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Imation Apollo (27119) 500 GB USB Hard Drive Logo
1,004 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
