Question about Dyson Vacuum. DC24 All Floors Bagless Upright Vacuum Cleaner 00158
The bruches are not turning I have checked the reset switch nothing on the bruch
The thing has great suction but it still dont spin ???
  • Geoff Brown Jan 01, 2013
    It did not help the Vac has great sucktion great belt no string or cotten on the bruch reset button is in the set postion I think the motor is shot
  • 1,564 Answers
Ok. First check your belt. Is it broken? Then if that's not broken, check the ends of your beater bar for a build up of hair, string, etc. This build up will stop your beater brush from working. If you can clear that stuff away well enough you might get lucky and have it work for a while. Otherwise buy another brush/bar.
Posted on Dec 30, 2012
  • 2 more comments
  • Geoff Brown Dec 30, 2012
    SYL the brush bar is very clean the belt is fine the connection pins are fine & the reset button is set I dont think the motor is any good ???
  • sylviaivie Dec 30, 2012
    Ok so we know the motor is working because the suction is working fine. Unless the dyson has a separate motor for the beater bar... that is. So what you need to determine is if the driving mechanism is turning freely from the motor, through the belt (or direct drive) and to the beater bar. I've had vacuums appear "clean" but actually have a build up of pet dander between the end of the bar and the cups on the ends of the bar that was not visable without some serious examination but we've already covered that. So you'll need to get to the motor and see if that armiture is turning freely. If it is the problem could be anything from a slipping belt to binding as discussed before. Good luck
    *if that isn't the problem....
  • sylviaivie Jan 01, 2013
    Ok so if you are pretty sure the motor is shot I guess your two options is to see about getting a replacement motor... or a replacment vacuum. And just use this one for vacuuming out the car or something.
The beater bar in my vacuum does not go around and there is no suction in the power head?
Turn up side down- check if belt is intact- I would remove belt ant look for an obstruction. Not familiar with this vac but some motors have replaceable bruches on the motor. Try running and feeling for suction. The motor should sound strong when running. Remove beater brush and check for freedom of movement.
Jul 28, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Bruch stoped
Replace belt and clean hair and debris from brush roll and end caps
Oct 25, 2013 | Vacuums
Bruch will not spin
Make sure the brush switch on the canister is in the on position. The handle must be reclinded for the brush to spin.
Jun 24, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
Vacume wont **** opened it up see nothing wrong HELP
If no suction usuallly means a clog, either in the hose and the dirt inlet by the brush roll. Sometimes if the belt is stretched, it won't turn the brush roll under load and it would seem like there is no suction.
Apr 19, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Roller brush doesn't move
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Oct 26, 2007 | Kirby Heritage II Vacuum
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Spin bruches don't touch floor.
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Apr 28, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Dyson Vacuum. DC24 All Floors Bagless Upright Vacuum Cleaner 00158 Logo
74 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
