Question about Hamilton Beach BrewStation 47214 Coffee Maker
Hamilton Beach Coffee maker stoped working
Hamilton Beach Coffee maker wont brew, you hear the coffie starting to flow down but then it just stops , if you press the botton again it will brew one quarter a cup then stop dead
4 Suggested Answers
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
  • 68 Answers
SOURCE: Hamilton Beach 40540 Brew Station 40-Cup Coffee Urn, Silver
Try to see your manual.
Posted on May 18, 2009
  • 570 Answers
SOURCE: how much coffee do i add into a Hamilton Beach
You may add 6 tsp of coffee powder or two coffee beans if u have a grinder
thanks
Posted on May 20, 2010
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
How do I get a copy of a manual for a Hamilton Beach Brew Station Deluxe Model #47454 ?
The manual is available on the Hamilton Beach product page: http://www.hamiltonbeach.com/coffee-makers-legacy-products-brewstation-deluxe-12-cup-coffee-maker-47454.html#careguides . (If needed, click on the Use and Care Guides tab.)
The direct link to the Use and Care Manual is http://useandcares.hamiltonbeach.com/files/840160504.pdf . (Note: Adobe Reader or a similar program is needed to read or print the manual.)
I hope this helps.
Feb 24, 2015 | Hamilton Beach Brewstation Brew Station...
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
Does not use all water
Try running a cycle with CLR, then a few rinse cycles of fresh water before brewing your coffee. It worked for me!
Jun 05, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Auto shutoff
some of these coffee makers have feed tubes, which can be seen in the rear water reservoir, that feed the hot water to the grounds. some of these tubes collapse when the boiling water passes through them , then kink , causing the water to stop flowing untill it either cools or is straightened. To check and see if this is occuring.. look in the back reservoir, if there's a tube running through it, note how soft it gets as it starts to brew.. be careful the water inside the tube is hot.. This indentify why it stops brewing partway though..
Sep 21, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Stops brewing before all water empties from reservoir
I went to Hamilton Beach site and read the troubleshooting. I followed there cleaning instructions and reduced grind time on my coffee and the machine is working perfectly again. I stressed over this problem for a long time before following their operating instructions. Have had the machine for over two years now and it's back to working perfectly. i.e. Run a pint of white vinegar through it. Wait 30 minutes and run another full vat of water....wait again and run another full vat of water. If you're grinding your own coffee, you may be grinding it too fine. Otherwise Hamilton Beach recommends the kind of coffee to use. Also the problem maybe too dense of a filter. This is all info I got on the H. Beach troubleshooting site. Good Luck !!! Mine is back to working great !
Jul 24, 2008 | Hamilton Beach BrewStation 47214 Coffee...
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
183 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
