Question about KitchenAid Refrigerators
KBFS22EWMS water in bottom of fridge freezes then thaws
There is water that freezes and then thaws and runs out of the fridge on to the floor.
  • 1531 Answers
SOURCE: Water pooling in the fridge.
excess water usuall y means there is a blocked drain tube in the bottom of the fridge.this can be cleared by using a small bottle type brush and run down through the drai hole to clear it.also check the drain tube from the rear of the fridge and make sure there is no obstruction near the drain pan
Posted on Feb 24, 2010
SOURCE: frs26zrg fride side by side leaks a puddle under
there id a hose which carry out water.
check that
Posted on Aug 06, 2010
aroracaty2
  • 503 Answers
SOURCE: My pull out freezer (on
sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 04, 2010
Sea Breeze
  • 4655 Answers
SOURCE: water freezes in bottom of freezer and then leaks out onto floor
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Posted on Aug 17, 2012
spyder301975
  • 101 Answers
SOURCE: water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Posted on Aug 25, 2012
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
My freezer is freezing at the drain hole so all the water is running into the bottom of the fridge
HI, either your drain tube is clogged or it will need a drain tube heater installed to prevent future freeze ups. Thaw out with hot water....
Jul 15, 2011 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
I've had this problem before, where the fan is frozen so the fridge is no longer cold but the freeze is OK. What the guy did last time was remove the floor of the fridge, and poured hot water on the fan...
fridge not going into defrost, freezing up coil, replace defrost control, should thaw out fridge, or your evaporator fan motor is burnd out, thaw fride first see if fan works, if fan ok ,derost timer, if not relace fan motor
Sep 06, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer & freezer work fine. Water stops when refrige is set at 38 degrees. To keep water from freezing we have to set the refrige temp to 40 degrees, but find that temp not cold enough. Water can...
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Jul 02, 2009 | Samsung RS2556 Side by Side Refrigerator
I have a problem with my freezer, it has water pooling then freezing in the bottom of the freezer. The water also runs out onto the floor. It looks to be coming out of the opening in the back of the...
Your defrost drain line is clogged and frozen over with ice.
Turn off the fridge. Remove the bottom freezer drawer. Take a hair dryer and thaw the drain hole at the back bottom section of the freezer. After you defrost the drain line pour 1/4 cup bleach into the drain hole.
Jun 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
GE Monogram refrigerator is leaking water on the floor
At some point the freezer got too cold and the drain froze (it is a poor design with a loop in the bottom). Once this freezes it will not thaw for a long time.
Here is what I did:
  • Remove all items from freezer and let it completely thaw
  • Pull unit away from wall to access rear
  • Cut loop off drain line where it hangs in drain pan
  • Place a bare copper wire (#12 will work) through the drain line and wrap it loosely around the heating coil above drain pan
  • Enjoy
Did this 6 months ago and have not had problem since
Mar 15, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Water freezing in bottom of freezer
There is a drain for your freezer that is pluged.It may be pluged with ice or dirt.Try unpluging your fridge until it is completely defrosted,4 to 5 hrs. with doors open.
if there is dirt in it it may flush out or your heater element for the defrost is not working.
Dec 18, 2008 | Whirlpool Refrigerators
Refrigerators Logo
14 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
