Question about Dishwashers
My whirlpool dishasher model wec25002 will not drain all of it's water. how can you check the drain?
  • cause Jan 18, 2009
    Sorry I should of said it is a portable dishwasher on the other side of the kitchen
    thanks
    c
  • 640 Answers
First check under sink where drain water goes out,,take drain hose off and see if your clogged,,keep me post onthejob,,i will walk you through...warning care dishwashers are not ground,,
Posted on Jan 18, 2009
  • onthethejob1
    onthethejob1 Jan 18, 2009
    same problem so start with the drain hose..you have the kichen sionk hook up make sure that sink mounting couping is clar..keep me posted onthejob
I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all hoses...no clog. The water will drain through the pump when the unit is unplugged. Is there a way
it sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Nov 10, 2014 | Washing Machines
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Whirlpool Washer with FL error code
Check the hot and cold water supply must be going to the machine
Dec 19, 2017 | Whirlpool Washing Machines
I have a 2000 model Whirlpool washer and it is
Hello, the drain hose may have disconnected from the drain valve, these is the hose that leads up to the external drain hose and has that U shape in it.
Thanks
Jun 11, 2010 | Washing Machines
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch shu5304uc/u06 does not drain
sounds like the pump has something in it or the drain line is clogged or kinked some how
Jun 07, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
