Question about Garden
Stalling does not run
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
If you know how to properly take apart and put back together an engine block then open up the cylinders. Then clean out any rust or dirt in the cylinder. Once you put it back together and it still does not run then check the fuel lines for any plugs or breaks in it. If you do not have a pretty good idea on how to do this stuff then I would recommend taking it to your nearest power sports shop and have them service it.
Posted on Dec 31, 2012
It will crank and run good for 10 minutes and shut off. Once it shuts off when you restart it, it will only run for a couple of minutes and shut off again ?
I would start by getting a can of carburetor cleaner and have it 'at the ready' and try the 'start, run stall, start run stall' operation again. Only THIS time, once the engine begins to stall, give it a couple of quick shots of the cleaner into the air filter to see if it stays running on the cleaner.
If it does, then it's still a fuel problem. If it doesn't, then it probably an ignition problem. I would be sort of leaning towards the ignition coil getting weak. The reason I'm saying that is your statement about it running (I'm assuming cold start) for at first, 10 minutes then it stalls. Start it again and it runs for a couple of minutes and stalls again.
This could possibly be from the coil getting warm/hot and not producing the needed spark. After a 10 minute run it simply gets too hot and stalls the engine. After the next restart, the coil is already warm from the engine and so it don't take as long for the coil to get hot and stall the engine again.
Hope this makes sense and helps you out.
Apr 25, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
1992 geo prism stopped running
there are 3 states,
  1. cranking robustly
  2. engine starts
  3. engine runs and sustains running, not stalling.
where does yours fail.
or was driving and it stalled or stalled and cant start (1,2,3?)
tell more get more.
Apr 15, 2014 | 1995 Geo Prizm
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
08 ss trailblazer stalls on take off
It can be low fuel pressure issue or clogged fuel pump.Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem :------
Thanks.
Nov 27, 2012 | 2008 Chevrolet Trailblazer
My car is turning on but stalls I have a Volkswagen Jetta 06 2.5 engine. PLEASE HELP
Vehicle starts but stalls.These types of problems are very common on most of vehicles.There are few possibilities,that can cause stalling problem on vehicle.The vehicle brand and model may differ but problem is same.------I provide you few suggested help link to troubleshoot these issue and solve the problem:-----------
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold? http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
-------------1994 Toyota 4Runner: Stalls and Stops While Driving? http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
-----------1992 Chevrolet stalls and shutdown? http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
-----------Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot? http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
------------Engine stalls when gas is given? http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
------------1990 mazda 323 stalls and quit running? http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
------------Nissan Pathfinder stalls and bucks on Acceleration? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
------------Car stalls when MAF sensor is connected? http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
-----------Car Engine Stalls While Driving? http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
--------- Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
These are few help links,that will help you to troubleshoot the issue and solve the problem.Please keep updated,if any more help required.Thanks.
Oct 20, 2012 | Cars & Trucks
98 ford escortLX starts and runs for about 1 min and then stalls
check fuel pressure regulator.+ vacuum lines going to it look see if gas in vacuum line.if so regulator rupture.
May 03, 2009 | 2000 Ford Escort
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
