Question about Garden
The belt on the cutting deck on my NZT, 52 inch mower deck keeps breaking.
When the grass is long 6 inches and the hight control is half way the belt just breaks.The sales person told me that the mower would handle 2 inch, thick branches no sweat I use the mower in my avocado orchard, it don,t work!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
The belt may not be that good of quality. Or you have it to tight. Next time it break I would recommend spending a couple extra buck on an industrial grade belt.
Posted on Dec 31, 2012
  • sodapops
    sodapops Dec 31, 2012
    Already pay top dollar for belts $170.nz. the addjustment spring as is the mower no more than twelve months old
  • bradenbean
    bradenbean Dec 31, 2012
    adjust the tension on the belt it may be to tight
  • 6 Answers
SOURCE: Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Posted on Apr 30, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
bargainbin2
  • 123 Answers
SOURCE: Craftsman 42 inch cutting deck riding lawn mower.
Some of the 42 inch Craftsman mowers Have a cable that goes from the blade leaver to the deck some have a linkage if it has the cable check it to see if it has broken. Find where it connects to the deck pully and pull on the cable wire not the cable cover and see if if comes out also make sure it is connected to the top of the idler pully. If it has a linkage there is a clip that holdes that linkage to the deck it most likely came off.
Posted on Aug 28, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 42 inch cutting deck riding lawn mower. I can not get the mower to to ingage. The belt appears to be tight and has not follen off the pulley.
Aug 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
