Question about Dell Vostro 3750 PC Notebook
Dell vostro screen divided into three sections
The screen is divided into thirds, with the middle third having normal color. The two out thirds are darker.
  • Dell Master
  • 7,627 Answers
Is it a Desktop Background issue? Open the Personalize page by right clicking a open space on the desktop, click on desktop background, bottom left, change to fill. If that not the issue, you may have a Graphics issue. Have you done any Software updates, changes? Have you tried a reboot without battery?
Posted on Dec 30, 2012
5 Suggested Answers
albaniafreak
SOURCE: Dell Inspiron 6000 visual going bad
restart your computer and go to settings and test your color maybe that should do the trick
Posted on Dec 20, 2008
  • 7 Answers
SOURCE: vertical lines on lower third of dispay on Dell Inspirion 6000
bad lcd or video cable is not making good connection or is bad
Posted on Apr 11, 2009
  • 108 Answers
SOURCE: the bottom third of my screen is black w/ fine
Dell Inspiron 6000 are notorious for developing screen faults. Dell won't do anything about it unless under warranty. Have the screen replaced by a repair shop unless you feel confident enough to do it yourself.
Posted on Jun 09, 2009
  • 3940 Answers
SOURCE: Dell Inspiron D530 - Screen Malfunction - Rainbow colors?
Reseat the display cable (under the keyboard) and while you have the lcd hinge cover off, inspect the cable where is goes thru the hinge assembly for chafing and possible broken wires.
If reseating doesn't help, RUN DIAGS
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=E3FE44D4AAF58D13E0301E0A5517246B&doclang=en#1
If they fail then replacing the LCD display cable and or the LCD would be next.
Posted on Dec 09, 2009
Apex ld4688
Sounds like a vertical scan out section ciruit problem. Contact any service technician.
Gopakumar Gopalan Google
Feb 25, 2014 | Televison & Video
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
My laptop is under a different owner and can't login how can I change the user name and password .. Is a DELL VOSTRO 1510
Is this your own computer?
If so, three methods for you to reset windows password.
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Reset .
Can it help you ?
Jun 16, 2012 | Computers & Internet
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel...
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Oct 16, 2010 | Computers & Internet
My samsung SX07 series is a little messed up. The sreen is divided into 2 sections one takes up about 2/3 the screen, and the shows the middle third of the screen. How do i fix that?!
Turn on the menu and if it is messed up also then you have a bad panel,...very expensive. If not, then it may only need a T-Con board. These are only available for versions SX07 & 8 and for SS03 & 4. Look at the right side for a sticker with your version number on it. I highly suggest you take it to a shop.
Aug 14, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Dec 09, 2009 | Dell Latitude D530 Notebook
What wires go to which colors while hooking up the dryer plug
Normally a 220V-AC dryer plug will have three (3) wires. Two (2) of these are 120 V-AC each while the third one is the ground wire. The dryer cord (plug set) will have three (3) prongs and three (3) wires with either ring or fork terminals on the other end. The ouside wires are the voltage supply, while the center (middle one) is the ground wire. Your manual should also show this in the installation section for your unit.
Connect them using the installation guide for your dryer, which should show the two outside connections for the power, while the center connection should show as the ground, but BE CAREFUL and check to be sure before plugging in the plug/cord set into the wall 220 V-AC receptacle!!
Typically, newer appliances have a green colored nut/screw indicating the ground connection/conductor.
Jul 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dec 18, 2008 | Dell Inspiron 6000 Notebook
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Dell Vostro 3750 PC Notebook Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
