Question about Yaesu FL-7000 Amplifier
How to connect a Yaesu FT450 to a YAESU FL7000 Amp
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
To give you the best advice and info for your query, try the following:
join yahoo group specific to your radio Make/Model, the team their will have great advice and info, plus you can download manuals diagrams and other great stuff for your radio, but please give them as much detail as you can, so they can help you ASAP.
All this is free.
I hope I have been of assistance to you.
Cheers,
Peter
Posted on Mar 07, 2013
vrc_tech
  • 109 Answers
SOURCE: VX-1 Service Manual
this address should help you out http://www.ham.dmz.ro/yaesu/vx-1r-ext-mic-diagrams.php
as for the service manual you will have to order that from yaesu or see if the local Ham radio sevice shop has an extra one they will sell.
Posted on Aug 21, 2008
randy54156
  • 55 Answers
SOURCE: yaesu radio transmitter receiver
Theirs no reason why you cannot plug in the 110 adapter to the 110 wall plug to power the radio.
You may also want to add a surge protector inline.
Posted on Nov 08, 2008
robshow
  • 367 Answers
SOURCE: I need user manual for Yaesu ft-416
Click here for pdf user manual for YAESU FT-416
Hope this helps
Posted on Jan 16, 2009
SOURCE: Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Posted on Apr 07, 2009
  • 3289 Answers
SOURCE: how do i get expanded freqs on my ft1802 yaesu
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Posted on Sep 19, 2009
How to reset a yaesu fl-7000 radio.
According to Yaesu, the FL-7000 is a linear amplifier. Do you perhaps mean a FT-7000?
Dec 01, 2014 | Yaesu Radio Communications
Can you connect a siris or Delphic this to a yaesu transceiver
most yaesu transceivers are not capable of tunning the wide band FM broadcast band needed to hook up sirus or delphi satellite radio
Nov 28, 2014 | Yaesu Radio Communications
How to reset yaesu vx300 vhf radio transceiver
While turning on the device,at the same time push another button.One of the other buttons should re set the Yaesu.
Oct 10, 2014 | Yaesu Radio Communications
Need to couple Astatic D-104 mike to Yaesu FT-847 Radio
Check the wiring diagram online for both. It's a pretty simple connection setup.. Look at mods.dk for possible answers.
Feb 12, 2014 | Yaesu Radio Communications
Dead Yaesu FT60R
There is probably an internal fuse which has blown. Send it to the Yaesu service center for repair. They're reasonable and will do good work...
Jun 27, 2013 | Yaesu Ft-60r Dual Band Handheld Vhf / Uhf...
Replacement mic for Yaesu MH-27B8
Hi Neil,
I'm guessing you've tried your local yaesu dealer, without success.
If this is so, try searching the web for other Yaesu dealers/distributors, otherwise try ebay, of join yahoo group specific to your radio Make/Model, where you can get more info, plus you can download manuals, diagrams and other goodies.
I hope this is useful.
Regards,
Peter
Jan 29, 2013 | Yaesu Radio Communications
How to connect a Yaesu FT990 to a Ameritron AL80A Amp
Instruction on page 9
Yaesu FT990
Use "RLY" terminal as an input for triggering the
Ameritron AL80A Amp
Sep 19, 2012 | Radio Communications
Yaesu FT-726R repair shop?
The cheapest way to repair your Yaesu, is to find a friend who is an amateur radio operator, these people know radios, and work on radios as a matter of course as their hobby, otherwise it's off to a radio workshop you go, and be prepared to part with some cash.
There are no freebies with quality branded radios, only cheapies, if you know the right people.
I hope this answers your query, and by the way, I'm in Australia, you never mentioned your location.
Cheers,
Peter
May 30, 2012 | Yaesu FT-726R Transceiver
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu FL-7000 Amplifier Logo
99 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
