Question about Honeywell HT900 Table Fan
How can I remove the fan blades from my honeywell table fan? I took the 6 screws out and removed the grill already
First remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Posted on Dec 30, 2012
Perhaps if the manufacturer provides a picture of how you can do the cleaning it would be much easier.
Posted on Feb 07, 2013
4 Suggested Answers
SOURCE: Removable grilles for easy cleaning?
We just figured this out ourselves. There are four (4) screws on the back of each fan that when undone it releases the grill for cleaning. But the fun part is getting the screws back in to the little holes. But all in all we got it clean...
Posted on Aug 21, 2008
  • 260 Answers
SOURCE: HT800 Honeywell Fan Has Two Screws that Can't be Unscrewed
Just bu a clean air can used to clean a computer desk top much easier.
Posted on Apr 09, 2009
SOURCE: how to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Posted on Feb 08, 2011
How do I clean the table fan? It is very dirty.
Remove the front grille with a phillips screwdriver, there are also two T10 Torx screws on the top and bottom. Wipe everything down with disinfectant wipes. Do NOT use water, with the exception of the front (dry it thoroughly). Don't remove the fan blades. Replace the front grille and screws.
Jun 25, 2015 | Honeywell HT-800 Table Fan
I HAVE A Vornado Type 630 fan. How does one remove the cover so that the fan blades and circular grill can be cleaned. Tahnk you, Joanna
There are three clips the hold the grill to the cowl.
One clip at 11 o'clock, one at 2 o'clock and one at 6 o'clock.
Use a flat blade screw driver to push the 11 and 2 positions down (do 11 then do 2) and the grill shold come off.
I can send pic if needed.
cawicks at g mail . com
Feb 14, 2011 | Vornado Circulating Fan
How do I clean mynvornado fan blades
Look along the outer edge, on the back.
Use mild soap and water the clean the blades after removal.
Dec 18, 2010 | Vornado Circulating Fan
How to open fan to clean blades honeywell model
Apr 15, 2010 | Honeywell Dryers
Removing the hex screws from the table fan
you need a security bit it will have a small hole in it just for the screws you are trying to remove
Jul 26, 2009 | Honeywell HT-800 Table Fan
Cleaning the fan
There are 4 small screws in the rim between the ribs accessible from the back. Remove the screws and the cover will come off.
Jun 18, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Apr 05, 2009 | Honeywell HT8002 Table Fan
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Jul 20, 2008 | Honeywell Dual-Action Air Circulator Fan -...
The fan has hair and dust trapped inside so it can't turn correctly... it takes awhile to start up and has trouble turning. Is there any way to take it apart to clean it?
just had the exact same problem. there's 6 screws to remove along the back side of the fan grill, 4 of them are philip and 2 of them torx. don't know why they didn't just make them all the same! once the screws are out, you can take off the faceplate. you can then clean most of the fan, however it will be difficult to clean the area near the motor.
Apr 03, 2008 | Honeywell HT-800 Table Fan
Honeywell HT900 Table Fan Logo
256 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
