Question about Akai MPK mini MIDI Controller Keyboard, 25-Key
Akai mpk broken conector
Hello, the mini usb conector of my akai mpk mini broke, the warranty is out and i want to change it by myself. Anybody have the diagram? I found the diagram of the pins in the usb female conector, but i dont find anything about the controller in the internet. (Excuse my for my bad english, is not my first language) Thank you.
    New Friend:
    Problem Solver:
This video shows you how to repair the Akai MPK Mini USB connector without doing microsurgerty on the connector.
https://www.youtube.com/watch?v=vvhh-cWpMzI
Even after you repair the USB connector it may break again. Once it breaks, many time it rips traces from the board. It's difficult to solder a new USB connector if you're not very experienced soldering small SMD componenst.
I repair these both ways. The cable version lasts longer and is more reliable. The connector version keeps it original.
Posted on Dec 07, 2014
  • 2,427 Answers
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Posted on Dec 30, 2012
  • 2 more comments
  • mandragotrax
    mandragotrax Dec 30, 2012
    Yes i know, but the problem is with the controller. A little bit of the circuits where the connector is are broken too, because of that i have to change some connections for small pieces of cable. I know the standard on the connector, but i dont know where to connect it to the diferent circuits on the akai. This is the reason why i ask for a diagram of the controller
  • mandragotrax
    Thank you very much for your help, and excuse me for my bad english
  • Rishi Roshan Ali Dec 30, 2012
    sorry i took a bit to respond, I checked for the schemetic online and there is non,, you will need to requiest it from akai,, you can try bridgeing the broken circuit using solder.. Its what i do to fix broken circuit boards.
  • mandragotrax
    mandragotrax Dec 31, 2012
    Thank you, i'm waiting the akai's response
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
Can I get my akai keyboard port repaired as its damaged?
I see no reason why not...but that will depend what part of the country you are in...where are you located???
Jan 20, 2014 | Akai MPK mini MIDI Controller Keyboard,...
No sound
no sound well it has to be used w something from garageband reason, etc u cant just plug it in and play it . so for instance garage band , you wanted the grand piano u open the grand piano and start hitting the keys. should be no problem I have the same one
May 14, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Is the MPKmini compatible with sony music studio8
It should work as a generic midi controller if it isn't listed
Mar 11, 2011 | Akai MPK mini MIDI Controller Keyboard,...
My knobs of my AMAY MPK mini just don't work!
This is likely a software you are using with this is either not compatible with those particular controllers OR is not set up to use those controllers. Someplace those need to be mapped into whatever you are trying to control with the knobs.
Mar 07, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini...
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Jan 29, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Open Questions:
Akai MPK mini MIDI Controller Keyboard, 25-Key Logo
548 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
