Question about RC Micro X Copter Mini RC Helicopter
Open the remote controller power - RC Micro X Copter Mini RC Helicopter
Does anyone know how to open the case of Philips TV remote control RC4401?
This remote control is not clicked as you may expect, it's been screwed inside.
To open the remote control, you have to gently peel off the front gray panel using a unsharp knife, beginning to the top (near the power button).
Once removed, you can access to 10 small screws that holds the blue frame (partly visible on the edge).
Once opened you can access to the electronic and the buttons.
Then you will certainly be disappointed to discover that some buttons (the Power for example) are not reparable. A small pin breaks when excessive force is applied. Gluing this pin does not help either.
This is a throw away remote control, better buy a universal that does the most used functions.
Oct 30, 2014 | Televison & Video
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
How can I change the region on my Toshiba SD K860?
1. Power on the DVD player
2. Press the Open/close button on your remote control to open the drive tray and remove any disk
3. Press 2403960
4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
5. You will see a 9 (region-free) on the TV (right corner)
6. Press the Open/close button on your remote control to close the drive tray
7. Power off the DVD player
8. Power on the DVD player and it is region free.
May 22, 2011 | Televison & Video
I'm tryna program my toshiba sd 3960 but I can't find the manufactures code... can any one help I would extremely appreciate it thank you...
Here is a possible hack for TOSHIBA SD 3960.
Press 'hold' for a few seconds.
Release.
Pres 7,8,9,OK,0. (or possible ENTER button)
In the left corner you should see a 0.
That is it
OR the following steps
1. Press the Open button on your remote control to open the drive tray
2. Press the 2 button on your remote control
3. Press the 4 button on your remote control
4. Press the 0 button on your remote control
5. Press the 3 button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 0 button on your remote control
9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback
10. Press the Open button on your remote control to close the drive tray
11. Power off the DVD player
12. Power on the DVD player
Nov 13, 2010 | Toshiba SD-3960 DVD Player
Just bought a lg dv550 and am looking for the multi region code
1. Press the Open button on your remote control to open the drive tray 2. Press the Pause button on your remote control 3. Press the 0 button on your remote control 4. Press the 0 button on your remote control 5. Press the 0 button on your remote control 6. Press the 0 button on your remote control 7. The onscreen display should now prompt you for a new region 8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 0button for multi-region playback 9. Press the Pause button on your remote control 10. Power off your DVD player 11. Power on your DVD player
Jul 15, 2010 | LG Televison & Video
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Feb 27, 2010 | One For All URC-4605 Remote Control
What is the region code for toshiba SD-K750 DVD player
hello,
Pressing the Open button on your remote control to open the drive tray, Press the 2403960 button on your remote control
region 1, 2 for region 2, and so on, or 9 for multi-region playback, Press the Open button on your remote control to close the drive tray, Power off the DVD player, Power on the DVD player
Report this hack (requests/questions/spam/wrong/****).-->
Jan 04, 2010 | Toshiba SD-K741 DVD Player
Unlock code
This is a code for other models but it works on about half a doz Tosh models.
It may work, i cant test it out for you so, its up to you if you want to try it will either work or not.
1. Press the Open button on your remote control to open the drive tray 2. Press the 2 button on your remote control 3. Press the 4 button on your remote control 4. Press the 0 button on your remote control 5. Press the 3 button on your remote control 6. Press the 9 button on your remote control 7. Press the 6 button on your remote control 8. Press the 0 button on your remote control 9. Press the Enter button on your remote control to change the region to 1 for region 1, 2 for region 2, and so on, or 9 for multi-region playback 10. Press the Open button on your remote control to close the drive tray 11. Power off the DVD player 12. Power on the DVD player
Oct 25, 2008 | Televison & Video
I want to buy a dvd player bush modelDVD2054DIVX or a wharfedale with HD upsscaling in IRELAND and bring it to MAURITIUS.I want to know if they will play normally or there will be region code or something...
Heres the code for the bush. don't know about the other one though.
To convert this player to multi-region
1. Power off your DVD player
2. Power on your DVD player
3. Press the Open button on your remote control to open the drive tray
4. Press the 1 button on your remote control
6. Press the 3 button on your remote control
7. Press the 0 button on your remote control
8. Press the 0 button on your remote control for multi-region playback
9. The onscreen display will indicate the currently selected region
Jul 28, 2008 | Televison & Video
Bose 3.2.1 GS II region free
TRY THIS Multi-Region:
1. Using the remote control, key in the following: 9, 4, Shuffle, Stop, Mute.
To set a specific region:
1. Using the remote control, key in the following: Open (to open the tray - if already open, no need to press it), Stop, Shuffle, followed by the region number.
2. Press the Enter button on your remote control.
Jun 07, 2008 | Bose 3·2·1 II System
RC Micro X Copter Mini RC Helicopter Logo
80 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
