Question about Sharper Image TSI-UR100-5 5-IN-1 Universal Remote
How do i program the shaper image tsi-ur100-5 remote
How do I program The Shaper Image 7 in 1 univesal TV remote control with no codes or manuel?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 17, 2014 | Televison & Video
My tv is rca. i need tv code for a shaper image remote
check the website
http://www.rca4tv.com/purchase/index.asp
then if you really want to have a universal remote . then ask the company may be they have !
do vote if it helps you
Mar 31, 2011 | Televison & Video
Need instructions and codes to program Sharper Image Jumbo Remote
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual. Click the above links to download these remote manuals.
I hope that helps.
Mar 22, 2010 | Sharper Image TI150 Iron
Need power cords
look at thrift store, most cords should work, with little or no modifacation.
Oct 06, 2009 | Sharper Image SA260 CD Shelf System
Lost guide book for emerson jumbo universal remote. need code
My guess is that it's the same as the Shaper Image Jumbo remote. Go to http://mscustomercare.com/. There's pictures of both. I just downloaded free instructions, will try them myself tomorrow.
Jan 09, 2009 | Televison & Video
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
SHAPER IMAGE OUT OF BUSINESS
Sharper Image has recalled all Ionic Breeze Ionizers. This is what put Sharper Image into chapter 11.
For information see the link
See the EPA link as well
Jul 12, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Jumbo Universal TV Remote (Sharper Image-Innovage)
sharper image jumbo remote can't get it to program my philips/magnavox tv.
Dec 25, 2007 | One For All URC-9910 LCD Remote Control
Sharper Image TSI-UR100-5 5-IN-1 Universal Remote Logo
75 people viewed this question
Top Sharper Image Televison & Video Experts
ray gallant
Electro Med Services...
Are you a Sharper Image Televison and Video Expert? Answer questions, earn points and help others
