Question about Altec Lansing AVS 500 Computer Speakers
Is the capacitor in the a/c adaptor or in the base unit
Had service interrupted yesterday and had it restored today but i cant get my phone to work
Can you please provide us the model number of this unit so we can help you better....
Oct 31, 2008 | Panasonic Lands Phones
Uniden ac adaptor input120v output9v convertingto 220v
normally the adaptor has a switch for converter 11oVac to 220vac. If you adaptor do not have, you must ask to the company to provide a new one. Otherwise you can not connect it. You can damage the base unit.
God bless you
Jul 22, 2012 | Uniden Cordless Phone
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
Base no longer working. Unit is plugged in.
go to your neighbour"s house and check it there.
Base Unit does not work
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Dec 17, 2008 | Panasonic KX-TG4500B Phone
The base unit goes blank no display
I had this same problem. It turned out to be a bad power adapter for the base unit. If you have another handset that has its own charger than the power adapters are interchangable. try swapping them and see if this fixes your problem.
Mar 08, 2008 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
My base unit has just got locked and am not able to access any keys.
unplugging it for a few ours possibly over night should reset it while your at it go ahead and take the battery out of the phone and let it set to
Feb 06, 2008 | Panasonic KX-TH112 Phone
The phone is constantly searching for network
It seem that the base is either bad or there is no power supplied to the base from the power adapter. Check and see if the charging light is coming on if it is then you have to replace the base unit and re register the handsets to it. If it is not then most likely the power adaptor is bad. It is difficult to check the adaptor with out a meter but if you know of a way you can try it. If the adaptor is good and there is no charging light on the base then the base definitely is bad. Good luck
Jan 02, 2007 | Uniden Cordless Phone
Altec Lansing AVS 500 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
